Old 09-04-2013, 06:29 PM
Rembrant88's Avatar
Rembrant88 Rembrant88 is offline
Default 1980's Jeep wagoneer Axles Scout 800 Swap
I did some searching but couldn't find much on the subject. If someone were to provide a link to a build than that will help. Could be I missed something in the search.
So I might pick up my buddies 1966 scout 800. I thought it was an 80 but turns out it's the same year as mine. I was considering going with his 6.2 diesel swap idea but if I get it I'm most likely going to go with a ford 302 and e4od transmission. I bought a 93' bronco to swap the guts to from my wrecked 86' bronco with a 6.9 idi. So I'm going to have a 302 with 147,000 miles on it as well as a good transmission lying around. Now of coarse that leaves me with a drivers side drop problem. So my idea is to pull a drivers drop dana 44 out of an early 80's wagoneer and naturally the rear as well. I'm aware of what is involved with a scout 2 dana 44 swap but not jeep 44's. Anybody know what difficulties are involved here? Any special problems with the swap? Thanks.
I'm sorry if ford and jeep stuff in a scout bothers anybody. I'm just trying to save the scout from possibly being crushed, so I think it is a good alternative .
Old 09-04-2013, 10:22 PM
az scout guy's Avatar
az scout guy az scout guy is offline
Default Re: 1980's Jeep wagoneer Axles Scout 800 Swap
The waggy rear is soa and the front is sua, spring hangers/ perches need changed. If you can think and weld it ain't that hard. The waggy width is nice under an 800\80 and flat tops with Chevy brakes
http://canyonoffroad.com/
76 1 ton Traveler
SOA front
4 link rear
RS
High steer with ram assist
Chevy 350 TBI
700r4
Dana 300 with 4 to 1 32 spline output
D60 front OX 5.86
D70hd rear Detroit 5.86
40x13.5x17 creepy crawlers
A/C
Autometers
Daily driver/ scuggy now
Old 09-05-2013, 02:07 AM
Rembrant88's Avatar
Thanks for the reply. Luckily I can think, and weld. I've never tried both at the same time though, could be messy...
I know that on the scout 2 dana 44 front end the passenger side perch is a machined part of the gear housing. Is it the same on the wagoneer? If so than I might just do the same ford coil spring front suspension I'm doing on my other scout by buying the bronco wedges and forget messing with that perch. I seem to have a lot of ford parts around for that kind of thing.
Old 09-05-2013, 05:58 AM
Pretty sure the Waggy axle has the perch as part of the casting, I know the pass drop versions do.
Off hand I can't remember the spring spacving on a Waggy but IIRC it's pretty close.
Old 09-10-2013, 11:12 AM
carnuck carnuck is offline
There is a kit that's bolt on to make the FSJ axles SOA. I think it's TTFabworks
Old 09-11-2013, 05:56 AM
With the E4OD trans and it's Borg Warner t case, you rear driveshaft will be about 16inches long. I wouldn't consider a SOA practical with that short a shaft.
Old 09-16-2013, 02:03 PM
Rembrant88's Avatar
My plan is to use a ford np205 that I have in the garage. I can't remember how much shorter it is than the BG t case, 7" maybe? But it should be enough to make up for the extra length of the e4od wouldn't you think? I can always keep the front spring under and make the rear spring under. I don't care either way because my tire size will be 30's and it's not going to be doing anything serious off road.
Old 09-17-2013, 06:01 AM
Pretty sure the 205 will gain some length on the shaft. But if you don't plan a lift even the short shaft should be ok. It's the angles of the u joints that get to be a problem and the angles grow faster with a shorter shaft per any amount of lift.
I don't see anything wrong with either case as long as you keep em full of oil.
Old 09-18-2013, 02:18 AM
Rembrant88's Avatar
Well, scratch the 302 idea. Someone went and gave me a free motor tranny combo. I don't think length will be a problem anymore. The np435 is a short transmission.
http://www.binderplanet.com/forums/s...370#post855370
Old 09-18-2013, 05:38 AM
Scavenger Scout Scavenger Scout is offline
205 cases are clockable and there's no need to stay driver's side drop
196 , 1966 , 1980 , 302 , 800 , axles , bronco , build , dana 44 , diesel , find , ford , front end , jeep , pick up , problem , rear , scout , scout 2 , scout 80 , scout 800 , suspension , swap , transmission
Scout 80 vs 800 axles question Mike Woodman General IH Tech 12 10-19-2012 05:07 PM
23rd Scout/Truck Nats Show n Shine Results John Glancy General IH Tech 12 09-18-2012 07:23 AM
2012 IH / Scout Nationals Award Winners crazyeight Tennessee Valley Binders 0 09-13-2012 08:20 PM
345/727 swap into Scout 800. 800 engine bay pics wanted. 350IH80 General IH Tech 6 11-03-2010 08:23 PM
Scout 2 axles under an 800 harvey General IH Tech 2 03-14-2006 06:10 PM
