SEBA Winter Meet and Greet
Old 09-18-2003, 10:24 PM
Blackdog's Avatar
Blackdog Blackdog is offline
Default Scout 800 power steering
Will the power steering from a 800a V-8 Scout fit on my 800 4 cyl Scout?
Old 09-19-2003, 09:46 AM
grannygear grannygear is offline
Default AAhhh...
...I don't think any 800 came with power steering. My V8 800 did not. I swapped on SII stuff.
There are other options for the 4cyl ones. The box is on the inside of the frame...yes? The V8s manual box mounts to the outside of the frame.
1967 800...a work in progress. 3 Years later and finally out of the garage!http://www.c4x4.com/tech/projects/oldscout/mainTOS.html
Old 09-19-2003, 01:27 PM
Justin Graham's Avatar
Justin Graham Justin Graham is offline
Default 4 cyl. Power Steering
There's a write in the FAQ about converting a 4 cyl. Scout 80/800 to power steering. Little different the V-8 conversion because the box in mounted on the inside of the framerail. Need to use the box from a 78-79 F250, probably could use the pump from a Scout II with a custom made bracket. I've been comtemplating doing the conversion on my '63 Scout 80, so I've done a little bit of research. Members REF and Trad Bowhunter Dan have done the conversions, they may be able to provide you with a little insight. Good luck.
Justin
Old 09-20-2003, 12:23 AM
Damian Grihalva's Avatar
Damian Grihalva Damian Grihalva is offline
Default Re: Scout 800 power steering
I've heard of the ford box, and I've seen it work ~ I used a Scout II box. Put the whole write up on my website. Click on: http://www.dandcextreme.com/extremebuildups.asp - then Click "Beater Buildup" and the write up is on "Day 33" through "Day 35" ~ but the box mount is on "Day 34" ~ I've even got pictures of both the ford box AND Scout II box going in.
Check it out.
Damian (a.k.a. Snoopy)
Evolution Build
Rusty's Buildup
More of my Builds
800 , click , conversion , custom , faq , frame , pictures , power , power steering , scout , scout 80 , scout 800 , scout ii , steering , website
Towing a Scout 800 manual Nishnabotna General IH Tech 5 02-20-2004 05:22 PM
