Old 01-21-2013, 10:38 AM
roadkingcat's Avatar
roadkingcat roadkingcat is offline
Send a message via Yahoo to roadkingcat
Default max lift without major driveline mods
I have a 77 scout 2 and want to keep driveline stock but bump up the height a bit for better stance. Also to pass strict safety inspection. Ill drive it like that till the budget allows for a major change. Thinking 2 inch body bushings and maybe 1 inch shackel lift.
It will be mainly road use for the time being.
Whatever I can do without getting the pinion angles past their sweet spot and having driveshaft issues such as coming apart..
1977 Scout II 345 automatic.
Former fire dept. Vehicle for small airport
1979 Scout ll 304 3 speed manual transmission.
Old 01-21-2013, 12:17 PM
Tim Potter's Avatar
Tim Potter Tim Potter is offline
Default Re: max lift without major driveline mods
4" spring under is about max lift without having to change drive shaft lengths or going to CV shafts, but the stock shafts will just about be extended to their limits. With a manual transmission, it may be necessary to remove the wedges at the rear springs for better driveline angle to reduce vibration; it's not so important with an automatic transmission; could live like that for years depending on how extreme you wheel. No need for a cut and turn for this but, you may notice slight handling differences.
A body lift is a different matter. No effect on driveline angle from a body lift but, lots of other corrections need to be made. Try searching the subject, you'll find volumes of pros and cons information on doing a body lift.
1977 Terra 304, T-19wr, D20
1974 SII, 345, T-19W, D300, SOA, Deaver springs, D44 Alloy USA chromoly shafts, ARB front, high steer; D60, 35 spline semi-float shafts, ARB, disk rear, hydro boost, CV shafts, Bilstein 5125 shocks.
Old 01-21-2013, 12:21 PM
I would highly recomend not putting a shackle lift on the front,it will screw your steering up.You can usualy get away with 4 inch spring lift using your driveshafts,you will need different shocks and brake hoses.
73 travelette(summer daily driver,camper toter)73 travelall(show truck)
68 travelall(16 years into ground up no end in sight)85 bus(moble shed) 64 scout 80(daughters,sold) ,79 glass traveler(wifes)74 scout (4 inch lift,winter driver) 73 1/2 top 2 wheel drive(amandas)more to be added when found
Old 01-21-2013, 08:00 PM
Will Marsh's Avatar
Jeff's right. With one more caveat.
I'd replace the u-joints in the rear driveline while I was there unless they've been done recently. U-joints that have worn in for 40 years don't take a change in driveline angles very well, and it's not expensive or a lot of extra work when you're already under there.
HTH,
Will Marsh
Bill Cosby
www.redstate.com
Old 01-21-2013, 08:01 PM
Thanks for the info Tim and Jeff, I always thought I would do a 4 inch spring lift.
But they sound like they are a pretty harsh ride from what I've been reading.
Spring over axle is what I will likely go with. I'll just have to do it right.
automatic , body , body lift , bump , bushings , drive shaft , find , front , height , inspection , lift , manual , rear , remove , safety , scout , scout 2 , spring , springs , steering , stock , transmission , turn , vibration , wheel
Picture of a Scout with a spring-over lift and 33" tires? lightningflash General IH Tech 24 04-28-2013 05:19 PM
Scout II 2.5" lift next to a 4" lift - Side by Side Pic? jbolton General IH Tech 11 02-16-2012 07:50 PM
body lift kit Will Courtney General IH Tech 2 02-18-2010 11:39 AM
rag joint replacement for body lift Alex -S General IH Tech 22 03-11-2009 11:43 AM
Max lift without front axle mods. larboc General IH Tech 2 12-27-2005 08:02 AM
