Old 08-08-2012, 01:26 AM
Sammy Sammy is offline
Default Re: P/U Wheel Bearings - Part Number or Cross Ref?
I have a set of those and AFAIK the 1110's were open knuckle, drums and internal hubs. Who knows what can go on one in 40 years and ? number PO's.
1972 Scout II
Old 08-08-2012, 07:00 PM
bravemen bravemen is offline
We'll you definitely right on what I have, I had to do a little more research over here.
Old 08-09-2012, 05:23 AM
200EIGHT4X4 200EIGHT4X4 is offline
The front wheel bearings for a FA46 are LM501349 cone and LM501310 cup,same inner and outer. So,you need 4 of each to do both sides. These are also known as Timken SET 45. The front wheel seals are Chicago Rawhide/SKF part number 24904.
Old 08-09-2012, 08:27 PM
You're fantastic.
110 , 1110 , 4x4 , axle , bearings , brake , brakes , broke , drum , external , fa-46 , front , grease , number , part , parts , pickup , seals , truck , wheel , wheels
Can't figure out front wheel bearings. jeffro General IH Tech 25 05-17-2010 08:41 PM
2 part question, 1.extended shackles, 2. wheel spacers... terd ferguson General IH Tech 20 01-24-2007 05:06 PM
Pro Comp Shock part number??? scout-ED General IH Tech 3 03-27-2006 12:59 PM
Timken #10 bearing rear axle? Brandon A. General IH Tech 17 05-04-2005 07:16 AM
Dana 27 FA wheel bearings janhighboy General IH Tech 6 05-19-2004 06:35 PM
