Old 08-04-2012, 04:12 PM
prof.tripp prof.tripp is offline
Default Tail lights = No beer. Help
i've got a 75' scout II 345. i've been pressing my luck, driving with a non-working drivers side tail light, brake light, and turn signal for years. i've changed the bulbs, fuse & traced the wires and all looks good. all my other lights work fine. is there an in-line fuse i'm missing? not sure where to go from here. any help would be much appreciated.
thanks,
David
Old 08-07-2012, 10:23 PM
scoutboy74's Avatar
Default Re: Tail lights = No beer. Help
It looks good? That can mean next to nothing. Have you verified the presence of voltage at the socket terminals with a test light? How about the grounds? Those lights all receive ground via the tenuous bucket to sheet metal contact. It gets real rusty and grimy back there.
Trever Whetzel
Fat White Boys
Binder Recovery
& Rehabilitation
SHOP NORTH
Old 08-07-2012, 11:42 PM
GregF's Avatar
GregF GregF is offline
moderator
I'm with SB on this. The ground was my problem and so I just put on my own new ground
with new screws in new holes. Problem gone.
Greg
The Fosters
You're right, you can't have just one!
76 Scout II Patriot
78 Scout Traveler
76 Scout Traveler Patriot (resting)
72 1110 4X4 pickup
Old 08-08-2012, 05:15 AM
FishWagon's Avatar
FishWagon FishWagon is offline
Same here. Going through grounds always fixes my light issues when it's not the bulb.
Thanks, and have a great day...
Rich
1979 Traveller 392/727/D20 Dana60/14B
1975 Travelall 150 2wd, 392/727
1974 200 4wd Dually 392/T19
Old 08-08-2012, 02:17 PM
good stuff. i'll check my grounds and test it with a meter. not much on rust back there, in So Cal. tenuous bucket?
thanks all
Old 08-08-2012, 02:30 PM
fredsterra's Avatar
I have had issues with these import crap light sockets keeping a good ground on the bulb. I have tried everything from bending the tab ground in the socket to a dab of solder on the bulb to the ground.
You just can't find good ones anymore since all of the OEM's went to the 3157 bulbs.
Mark Fredrick
Madisonville Ky
Old 08-08-2012, 06:31 PM
scoutboy74's Avatar
Well, it isn't the rust belt up north of you in Orygawn, but there is enough of it from mud and rain exposure to be a nuisance. I find myself shining up the ground points about once a year to stay ahead of malfunctioning exterior lights.
Trever Whetzel
Fat White Boys
Binder Recovery
& Rehabilitation
SHOP NORTH
345 , brake , brake lights , bulb , contact , fuses , ground , grounds , hose , light , lights , rust , scout , scout ii , screws , signal , tail , tail lights , test , turn , turn signal , voltage , wires , wiring
My tail lights mysteriously won't work.... foss General IH Tech 4 05-26-2011 03:32 PM
1100B Tail lights won't work HayMaker General IH Tech 1 08-13-2010 09:56 PM
Reverse lights/ tail lights kthesthag General IH Tech 8 05-25-2010 08:17 PM
no tail lights ihcman2003 General IH Tech 1 01-08-2004 07:21 PM
