Old 08-04-2012, 03:30 PM
Ristin's Avatar
Ristin Ristin is offline
Default Charcoal canister failure
I keep smelling fuel vapor when I have more than a 1/4 tank of fuel in the tank. My liquid/vapor separator was leaking and I fixed that but still smell fuel. Sniffing around under the hood, there was a strong smell around the charcoal canister so I took it out to inspect it. The bottom filter fell out and all the charcoal drained out. The piece that holds the charcoal in had crumbled apart.
Now what? If I tie the carb vent to the tank vent I assume I will have no fuel system ventilation and the system will pressurize when hot.
I can't find a direct replacement canister. Are there any current production units that can be made to work?
1978 Scout Terra 345,T-19 Close,D-20, 3.73 trac-loc, 31x10.50. Tilt wheel, 33gal tank, rust, oil leaks.
Past IH's:
1980 Scout II SD-33T
1962 Scout 80
When the mission dictates the form, similarities are inevitable.
Old 08-04-2012, 03:51 PM
Eric VanBuren's Avatar
Default Re: Charcoal canister failure
There should be tons of direct replacement cannisters in any wrecking yard that stocks cars and trucks from the 90's and earlier it is a GM unit and the exact same one as used in a ton of GM, AMC and many European cars from the era.
Old 08-04-2012, 05:32 PM
bazillion on ebay and lots of autoparts stores, its a gm item.
http://motors.shop.ebay.com/i.html?_...rcoal+canister
but why replace it?
stuff the vacuum hose from intake manifold that went to the charcoal can directly to the vent hose from gas tank.
leave the can there in place in case you have to fool the smog nazis.
Old 08-13-2012, 10:39 PM
Ristin's Avatar
Thanks Jay, I always forget about the Googler. Found one on Ebay should be here next week.
Past IH's:
1962 Scout 80
amc , can't find , carb , case , charcoal canister , ebay , filter , find , fuel , fuel system , gas , gas tank , hood , hose , hot , intake , manifold , replacement , shop , smog , tank , vacuum , work
Charcoal Canister = Vacuum Leak? Feedforward General IH Tech 8 04-03-2012 11:46 PM
How to route charcoal canister? Dave Meyers General IH Tech 18 06-04-2007 08:52 PM
carbon canister rusty General IH Tech 2 03-12-2006 07:40 PM
Charcoal canister hookup? Brandon A. General IH Tech 0 01-31-2005 07:04 PM
