Old 08-02-2012, 06:40 AM
FMhouse FMhouse is offline
Default Re: Possible 6.2 In a scout????
The 6.2 is considered a light duty diesel engine.Problems happened when guys with a 6.2 in a dually hooked up a 30 foot stock trailer full of steers and drove around with the foot on the floor for hours on end.If you don't abuse them,they are fine.I have one that has 400,000 miles on it and has never been opened up.
The block cracks in the main saddles is one known issue.Another is that sometimes the harmonic balancer rubber breaks down,this allows the outer ring to shift,which can throw off the balance and lead to a broken crankshaft.So look closely at the balancer and replace it if required.
Like any engine,overheating can cause cylinder head cracking and head gasket issues.
There are a few other upgrades that can be done to make the engine more robust,but they are cheap enough now that I just keep a spare or 2 around.
I am running a stock rebuilt 6.2 with a turbo in my '59 GMC and have good power without any issues.
Old 08-02-2012, 09:00 AM
wolverine223911's Avatar
wolverine223911 wolverine223911 is offline
So you are saying that the 6.2 would be a great engine for a scout then ok. With the exhaust on the 6.2 would there be any problems with interfearence with the firewall. Also does any one have any pics of this setup in there truck. Also if I do go this way is there any one out there in Indiana / Michigan have a decent 6.2 that they would want too trade or sell?
1976 Scout II 392 IC, T19 W, waiting too get home this october too start rebuilding the old girl
Brothers Fallen but not Forgotten
Spc Patterson
Spc Tauteris
Sgt Leonhardt
Sgt Metsger
Spc Perez
Spc Taylor
Old 08-02-2012, 01:47 PM
pretty sure this conversion has been done before so maybe try the search function and see what turns up.There are usually several good hummer 6.2's on ebay,but the best way is to find a good one in an old half ton and buy the whole rig,then you get all the little bits and pieces that make a conversion easier.Good luck.
Old 08-02-2012, 03:09 PM
Sammy Sammy is offline
Username Tres03 He has a thread on Hill Country Binders. Put a 6.2 in a Scout 80
1972 Scout II
Old 08-04-2012, 11:20 AM
chris rylance chris rylance is offline
I was at advanced adapters a while back, speaking with one of the guys there about engine swaps and he recommended the 6.2. As I understood it is a direct swap for a sbc and their adapter kit would work for both. Obviously there is additional work needed to go from gas to diesel. Personally I would call them and ask for clarification.
Old 08-05-2012, 04:26 AM
sounds great too me and thank you guys for the help, also if anyone has anymore info, pictures, or links please send them my way Thank you everyone
Spc Patterson
Spc Tauteris
Sgt Leonhardt
Sgt Metsger
Spc Perez
Spc Taylor
Old 08-12-2012, 08:40 AM
irhunter irhunter is offline
Do the mil spec 6.2s differ in any important ways?
I have heard the injection pumps on the 6.2s often tend to need rebuilds at <100k.
'67 T-all 1100 4x4 4-sp 304
'89 D250 CTD
Old 08-12-2012, 09:01 AM
Drifter's Avatar
Drifter Drifter is offline
All rotor type pumps have a hard time with the sulfur taken out of the diesel, there is no lube in the diesel. If you add a lube like hydrolic oil or any clean oil it will last a lot longer.
Old 08-12-2012, 01:18 PM
CareyWeber's Avatar
Diesel Herder / Moderator
The Military pumps are the best suited for handling the lack of lube in low sulfur because the internals are hardened to handle Military fuel that has even less lube than low sulfur diesel.
  • Carey
Old 08-12-2012, 01:40 PM
Drifter's Avatar
Why a 6.2 when there are so many other engines to choose from. I'm putting a 3.9 cummins in mine, shooting for 30 mpg.
392 , adapter , axles , bell housing , cooler , cummins , dana 20 , diesel , engine , kit , mount , mounts , nissan , parts , power , sbc , scout , sd33 , sd33t , swap , trade , transmission , transmission mount , wanted , work
