Old 07-26-2012, 10:08 AM
tecster tecster is offline
Default What goes here?
What goes in the empty hole... I need a new one - we had some fun trying to get that drum apart and did quite a bit of work to that drum....
Old 07-26-2012, 10:27 AM
Rob Peterson's Avatar
Rob Peterson Rob Peterson is offline
Default Re: What goes here?
Should have a stud to which the brake springs are attached - and it also provides a contact point for the brake shoes.
Rob Peterson
1947 KB-1
LS1 6.0 - NV4500
In progress . . .
Former METRO and S-140 Owner
Old 07-26-2012, 11:01 AM
Are these replaceable and if so where should I look to get one?
Old 07-26-2012, 12:31 PM
Fred Demmon's Avatar
I always thought that they were part of the backing plate
President
Gulf Coast Binders
75 SII 304 4 speed
65 80 152 3 speed
77 SII 345 Automatic
75 SII NO engine or trans
74 SII 196 4 speed
76 SII 196 4 speed
80 SII turbo diesel 4 speed
Old 07-26-2012, 12:53 PM
Meaning?
Old 07-26-2012, 01:19 PM
Big Ed's Avatar
Big Ed Big Ed is offline
Originally Posted by tecster View Post
Meaning?
On later vehicles they were not removable.
64 IH 1Ton,345,T34,T18,Np202,40"MTRs,crawl ratios,61:1,113:1,207:1,375:1,D70 front with ARB & 35 spline chromolly axles,RA15 rear with Detroit Locker,York on board air,custom 200 amp welder.
Iraq veteran 04
Old 07-26-2012, 01:28 PM
Where abouts would I approch to get it?
Old 07-26-2012, 01:58 PM
Eric VanBuren's Avatar
Lots of earlier rigs used anchor pins that bolted on. I don't know the source of the brakes on those trucks but if you can find out if they are a Bendix or Kelsey-Hayes design you may be able to find ones from any brand rig that uses that brand of system. It does look very similar to the ones used on later Bendix systems as used on IHs but not only do you need the right diameter to fit properly you'll want to verify the length is right for the width of shoes that fit yours.
Old 07-26-2012, 03:27 PM
It is the anchor pin, but I don't know where I can get one...that's the problem now.
Old 07-26-2012, 03:57 PM
To know where to start looking it would help to know what year and model we are working with. Then we can hopefully find out which shoes it takes, what other trucks and/or cars that used that system and thus broaden the vehicles you can look to get that part from.
196 , 1967 , 200 , bendix , brake , brake system , brakes , case , click , drum , find , fun , hose , part , problem , rear , salvage , springs , start , wheel , work
