Old 07-25-2012, 05:11 PM
Primer13 Primer13 is offline
Default How hard?
How hard is it to take a dash out of a 1969 d1000
Old 07-25-2012, 07:23 PM
Jeff Jamison Jeff Jamison is online now
Default Re: How hard?
Depends on what all you want to take out,if everything,I wouldnt say its hard but does take quite a while to do.You have to remove the face,then gauges,glove box,then dash pad(nits up onto studs from under it)then you can unbolt the main dash.
Old 07-26-2012, 09:29 AM
One six pack, two sandwiches and a lot of questionable verbiage, but doable!
196 , 1969 , box , dash , gauges , pad , remove , studs
InlineTube Hard Brake Line set 75ScoutII General IH Tech 18 08-15-2007 06:09 PM
Can hard top mount over roll bar? Mr. Joseph General IH Tech 13 08-06-2007 04:12 PM
Hard start when cold AND pointed downhill? Darel General IH Tech 5 01-05-2007 03:57 PM
SSII soft doors with hard top Yancy General IH Tech 5 10-26-2003 09:34 PM
