How to spray line the inside of a Scout 2 tub!! It really deadens the sound and block more of the heat from coming through the sheetmetal. You can actually carry on a conversation inside without raising your voice even with the top off.
click here for the BCB 4xFORUM **** click here for the Back Country Binders 4x4 ONLINE WEB STORE Last edited by John Fleck; 07-27-2012 at 05:35 PM. |
unfortunatly none of the pics show up..guess i gotta register which kinda stinks just for a info related thread.but hey i bet you do good work..i just cant view it-god speed
I prefer MonsterPaints MonstaLiner which is more UV stable and available in colors.
1980 Traveler 345 D44, 3.73, 727, 4" RC SUA w/4* shims, GM 350 TBI (16197427) |
Durabank is another good option which is UV Stable and comes in Textured or Smooth plus tons of color choices.
http://www.durabakcompany.com/?gclid...FXPDtgodPUEAkA |
anyone ever use herculiner? I have had good results with that and have caught it on sale for $49 a gallon
Why farm half when you can FARMALL! 73 scout II- "Agnus" 76 terra 77 trail scout (custom body) 79 GMC 3/4 ton (Dad's truck) "The General" 02 H.D. Sportster 883R |
I am all for the DIY products except when it does not give me the same results as the commercial version. There is a reason I buy the Wagner brakes over the white box, the Hella headlights over the cheap import, the Felpro gaskets over the cheap house brand, etc. It boils down to getting what you pay for.
click here for the BCB 4xFORUM **** click here for the Back Country Binders 4x4 ONLINE WEB STORE |
Wish I would have seen this earlier. I posted (http://www.binderplanet.com/forums/s...&highlight=bed) there about bed liners. Have you ever heard of dduplicolor bed armor with kelvar and do you have any thoughts on it.
-Kyle 1974 SCOUT II, 304 727, 4in RC, 3in body lift |
1. it's too thin. I am going to end up using at LEAST another can in some time to increase the thickness and durability. 2. It's soft... possibly too soft. It's meant for light duty applications. It'll be GREAT inside the cab, but if you're using it in a truck bed which will see real use, I'd look elsewhere. I good shovel scrape would probably scratch it up pretty well.
1971 Scout II - I need to to learn how to weld (or find a money tree) before she makes any more progress. |
The $200 SEM I sprayed in mine in 2005 still looks great with no fading, and has held up really well. It goes on as thick as you want it to, since it is a 2-part poly...not air-cured. It'll cure up in the mixing cup 2" thick!
Mike Moore www.ScoutcoProducts.com ______________ 1980 Scout II-Chevy LT1, 700r4, NP241, 3.73's, RS, 4" lift, 31's. Daily driver __________________
Scout LT1 swap: $3055 Leaving a riced out Honda with a fartpipe sitting at the stoplight: Priceless! |
In retrospect, I should've gone for a chemically cured product. I knew this going in, since I learned years ago that 2K paints are incredibly superior to those which use no hardeners... particularly when it comes to chemical resistance.
| bed , binderplanet , brakes , build , build up , colors , headlights , herculiner , info , liner , pics , pictures , red , sale , scout , scout 2 , show , size , sound , tire , top , truck , tub , work |
| MiniBuild 18 ~ Putting Scout II axles on an 800 | Damian Grihalva | D and C Extreme | 34 | 08-21-2012 07:46 AM |
| spray on rhino liner prices? | IH64Scout | General IH Tech | 10 | 06-15-2006 10:11 AM |
