Old 07-19-2012, 09:51 AM
Default Re: What rear end?
"I'm more or less looking to replace the thin locking "washer?" that is in between the two keeper nuts. It got bent up pretty badly, I'll also be looking to replace bearings "
That "washer" is also known as a "keeper" and NAPA has them. Sorry, I don't have the part number. They come two to a box. I ordered two keepers and got two boxes but the extras have already dissappeared into the maw of fellow club members.
Why replace bearings unless pitted or otherwise damaged?
Do replace the hub grease seal: RA15 hub seal CR33073 / National 456292SSR
Old 07-19-2012, 11:58 AM
Big Ed's Avatar
Big Ed Big Ed is offline
Originally Posted by Jim Grammer View Post
those look like 10 spline axle shafts!
My RA15 has 16 spline axles
64 IH 1Ton,345,T34,T18,Np202,40"MTRs,crawl ratios,61:1,113:1,207:1,375:1,D70 front with ARB & 35 spline chromolly axles,RA15 rear with Detroit Locker,York on board air,custom 200 amp welder.
Iraq veteran 04
Old 07-20-2012, 11:46 PM
tecster tecster is offline
Hub grease seal? I do believe I'm confused on its location lol
Old 07-21-2012, 10:11 AM
When you pull the hub off, the 'ring' holding the rear bearing in is a grease seal.
1300 , 196 , 1967 , axles , bearings , brakes , diff , drums , front , ground , hose , limited slip , lock , locker , number , part , parts , piston , power , power loc , power lock , rear , top , truck , wheels
Advice on moving Travelall with frozen rear end chud General IH Tech 20 10-11-2007 04:04 PM
Major Rear End Problems Eli D. General IH Tech 17 08-19-2007 05:11 PM
Need rear D44 end play ring and clutch ring 64binder General IH Tech 4 03-28-2007 10:56 PM
1968 1500 C Two Speed Rear End Stephen S General IH Tech 2 07-21-2006 05:27 PM
Clunk and other noises coming from rear end Gunnar General IH Tech 3 04-07-2005 12:03 PM
