Old 07-11-2012, 10:21 AM
Emjay Emjay is offline
Send a message via Skype™ to Emjay
Default Carburetor Qs 2300-C
Just pulled the carburetor from my 69 1200 D. Looks like I stripped out the hole for one of the fuel bowl screws. I don't know how to repair this any suggestions?
I have another carburetor that is slightly different. It came off a 69 1100 D 4 x 4 should I mix-and-match? Can I switch the carburetor entirely?
Old 07-11-2012, 10:27 AM
Default Re: Carburetor Qs 2300-C
put a longer bolt in the hole.
chase threads first. holley doesnt provide screws that are long enough, and using aftermarket screw gaskets makes matters worse.
MrWolf MrWolf is offline
Maybe you could just helicoil the stripped hole? Shouldn't take too much effort if the carb otherwise is good.
1978 Terra glass body 345 727 T20 D44
Old 07-11-2012, 10:56 AM
Thanks for the input Jay. Do I need to use aluminum screws?
Old 07-11-2012, 08:10 PM
Greg R's Avatar
Greg R Greg R is offline
I just ran into this sitch myself last week. Unless you tried to screw back into that hole, it may be salvagable. Chase, re-thread, the threads with a 12-24 thread chaser. If you cannot find a thread chaser that small, a 12-24 plug tap will work but be careful not to start and cut new threads. Use plenty of cutting oil and be sure, I say BE SURE to blow out the crud the tap will leave in the hole.
A dab of anti-sieze on the threads of the screw will lubricate and you do not need much torque on the screws to seat the bowl gasket.
Aluminum is bad enough, but aluminum screws in aluminum holes guarantees trouble around the block.
69 800
266 V8/4spd & D18TC/OD
4.27 D30/ D44
'56 S110 240 I6/4spd
'71 1210 345 V8/4spd 2WD
'67 Travelall BG246/4spd 2WD
100 , 110 , 1100 , 1200 , 200 , 2300 , aftermarket , aluminum , car , carburetor , cutting , find , fuel , gasket , holley , oil , plug , repair , screws , seat , start , switch , work
Carb swap in pictures, Holley 2210 to 2300. jeffro General IH Tech 35 10-20-2012 11:05 AM
Holley 2300 Carburetor Refresh MikeInMobile,AL BP IH Knowledge Wiki 0 09-21-2009 06:36 PM
Holley 2300 Upgrades MikeInMobile,AL BP IH Knowledge Wiki 0 02-20-2009 09:39 PM
Holley 2300 baseplate problem SCscoutguy General IH Tech 22 07-15-2006 11:28 AM
2300 throttle return spring jettisoned General IH Tech 1 08-11-2003 10:56 AM
