Old 07-11-2012, 01:12 AM
HVYW8IH HVYW8IH is offline
Default built 345 carburetor selection assistance needed
comp towing cam, .020" over pistons, stans tri-y headers, 4 barrel square bore.
MY WHOLE MOTOR IS NEW
I calculated nothing over a 500cfm would be needed. I just heard of someone on BP that has an 850cfm on THIER 345.....???
i'm leaning twords a holley
MY QUESTION: what carburetor should I mount on top of my BUILT IH powerplant that will give me good street performance and good offroad reliablity.
who loves thier carb? and what make/ model is it?
thanks,
Paul
Old 07-11-2012, 02:02 AM
JackOc's Avatar
JackOc JackOc is offline
Default Re: built 345 carburetor selection assistance needed
Holley 80457, is an awesome match in my opinion, its 600 cfm but just bolt right on to your squaqrebore and away ya go. I actually used a squarebore adapter on a spreadbore....very minor adjustment necessary
Old 07-11-2012, 11:03 AM
EFI!!
If you are actually going to use it off road then a carb just won't cut it.
If you are just going to drive down dirt roads or fire roads then a carb will be fine.
Old 07-11-2012, 07:58 PM
Greg R's Avatar
Greg R Greg R is offline
Depends on your style and wallet. I believe a 350 cfm would give you a nice response, power for the trail, and good street manners without sucking on every gas pump you pass by. But some folks have a lead foot, fat wallets, and want a fat carburetor for very heavy towing or bling.
In a pinch I put a 275 cfm Holley 2BBL on my 345 equipped 1210 and I love it. It hauls heavy loads and drives nice and I average about 12 to 14, well 11 to 13 with E10, mpg. I tend to believe carbs work better a bit on the small side because of the higher air speed through them and a better atomization/mixing and metering of the fuel.
Then there's Bill's injection and a good following for that.
69 800
266 V8/4spd & D18TC/OD
4.27 D30/ D44
'56 S110 240 I6/4spd
'71 1210 345 V8/4spd 2WD
'67 Travelall BG246/4spd 2WD
1210 , 2bbl , 345 , 4 barrel , air , cam , carb , carburetor , fuel , gas , holley , mount , performance , power , pump , question , top , towing , work
Swap a T-19 from diesel to 345 w/T-18? KnowtheCrow Diesel Tech 3 08-01-2005 05:25 PM
266 to 345 water temp sensor...where? greg General IH Tech 3 07-04-2005 11:52 PM
345 into 70 800. Scott Sinner General IH Tech 7 06-13-2005 02:49 PM
392 heads on a 345 grivera General IH Tech 4 11-18-2004 01:39 PM
carb assistance needed!! rustfreeTX General IH Tech 4 04-26-2004 02:52 PM
