Old 07-02-2012, 04:24 AM
wolverine223911's Avatar
wolverine223911 wolverine223911 is offline
Default Older Internatioanl help
http://southbend.craigslist.org/grd/3113007946.html
I saw this truck on creaigslist today and kind of liked it. I was hoping too get some info on this truck or even ideas if it is a good deal too go for it or not. As of now I do not know the condition but I am going too give the owner a call. Well Thank you guys for your help
Andrew
Old 07-02-2012, 04:33 AM
tecster tecster is offline
Default Re: Older Internatioanl help
Best bet would be to post up your questions in the Triple Diamond Trucks category. That's where I fall under too, I'm learning slowly but surly - sure is alot to learn!
Old 07-02-2012, 04:46 AM
Hurry. thats a little less than it would fetch in scrap prices right now. No seriously go get it before some does buy it for scrap!
Old 07-02-2012, 05:01 AM
[QUOTE=ruderunner;784410]Hurry. thats a little less than it would fetch in scrap prices right now. No seriously go get it before some does buy it for scrap![/QUOT
Ok sounds good and most likely I am gonna go for it but what type of truck is it and what was the basic drivetrain assuming that it is all stock and anything bad too look for reason why is I am not at home where I can look at it so I am going too have by dad go look at it for my and try too get pictures sent too and thank you for the replies too More are welcome
Old 07-02-2012, 06:11 AM
Royce Stephens's Avatar
Royce Stephens Royce Stephens is offline
It is an L series, probably an L 160. It should have the inline 6 SD 220 motor and a 4 speed tranny. It has a side tilt hood which is pretty cool. The worst rust issue on them is generally the lower end of the front grill by the turn signals. There is a stiffing bar just below the lights that caught debris and would rot through.
Good motor and nice trucks. My favorite truck I've ever owned was a 1950 L120.
SOUTHWEST SCOUTS OF OKLAHOMA
1967 Travelette 6bt project
1949 Farmall Super A
1974 100 4x4
Old 07-02-2012, 08:53 AM
Dennis Bernth's Avatar
Being a grain truck, it probably only has 30,000 miles on it since they only use it for four or six weeks out of the year. Also probably very light on rust since it likely didn't get run in the road salt....I could see that with an aluminum roll back or a tilt bed as a Scout hauler!
Old 07-02-2012, 09:09 AM
You are right dennis I was thinking of getting this and making it my scout hauler and for the price you cant beat it but more info about this paticular truck is welcome well thank you for all the post so far keep them coming
Old 07-02-2012, 09:39 AM
So I just talk too the guy about the truck and it sounded promicing he did say that the coil went out and it has a bad wheel cylinder, but my question is are these trucks four wheel drive because he kept talking about the something he was calling the 2 speed transmission and he said last time he used it it would not shift too low so he disconected a wire too just leave it in high. So is this a transfer case he is talking about or some sort of gear splitter. Also he said the cab and doghouse are in great shape and he did a rough but deacent paint job just too keep it from rusting but all together he said it is a solid truck and it wont take much too get it up so my dad could drive it home and store it untill I get home so should I go for it or is this truck a risk any suggestions and help are wanted
Old 07-02-2012, 10:04 AM
Scott Hickman's Avatar
Scott Hickman Scott Hickman is offline
It is not 4 wheel drive.
The seller is referring to the two-speed rear end.
It has an electric motor that shifts the two-speed differential from low range to high range and from high range to low range.
Brakes, an old truck with low useage will need the brakes gone thru, both the hydraulics and mechanics (shoes & hardware).
Possibly may need to go thru the fuel system also, carb, lines & tank if it hasn't been run frequently.
1975 "200" AWD
Western North Carolina
SEBA / Southern Scouts
Old 07-02-2012, 10:12 AM
Randall Barringer's Avatar
Randall Barringer Randall Barringer is offline
buy it!!!
GSA 1968 Travelall 1100C with barn doors, PTO winch, skid plates, power brakes,T-98, and a BG265.
1300 , 1950 , aluminum , bar , bed , craigslist , deal , front , front grill , grill , hood , info , light , lights , paint , parts , pictures , roll , rust , scout , series , tranny , transmission , truck , turn
Legality of using older non-CARB-approved portable gas cans? Patrick Morris General IH Tech 9 11-04-2011 09:18 PM
Pls advise: TX rules re: older veh's multiscout Hill Country Binders - Central TX 19 06-29-2009 08:30 PM
Website for folks with engines and older IH tractors Colin Rush Tractor Tech 0 12-06-2005 12:01 AM
Synthetic motor oils in older engines Dan Phariss General IH Tech 1 12-18-2003 07:59 AM
Older style fuel pump Greg R General IH Tech 4 03-28-2002 01:02 AM
