Old 06-24-2012, 09:05 AM
VooDoo's Avatar
VooDoo VooDoo is offline
Default Re: Looking for slave cylinder for 67 ih truck
Originally Posted by tinker View Post
I hope this isn't a highjack, I read this post and then looked at the leaky slave on my 1969 Metro MA1500 and sure enough the rod is out of alignment! My first question is can anyone look up a part number for the original clutch slave? The one on there for the past decade isn't rite to match up. Then suggest a good sources to try? I doubt this is the same part as the C series.
Loca parts stores couldn't help
Thanks
Danny
A picture of your setup would help. If it is a 1" core slave I'm "guessing" it's the same, but the Metro guys will know for sure. Check out my build thread post #13 to see what the OEM IHC "C" series slave looks like.
http://www.binderplanet.com/forums/showthread.php?t=110323
Curious where it is located on your Metro and how much out of alignment it is? Pic!
68 Travelall 4x4 Do-It-All-Rig: 392V8, T35, NP202, 4.11's, 14B, HD D44, 4" Lift, 4W Disc, H2's with 34.5" BFG AT's (Ongong project...)
I can remember when the only carbs anyone cared about were under the hood!
196 , 1967 , 1967 parts , alignment , build , clutch , cornbinder , cylinder , dead , ih truck , ih truck parts , ihc , master , mount , number , part , pickup , piston , price , rebuild , replacement , series , truck , wrenching
Dead Cylinder Caused By Bad Brakes? mike4514 General IH Tech 12 11-16-2010 09:37 PM
Towing with an IH Truck Bren B General IH Tech 17 01-04-2006 07:08 PM
