Sometimes the axle shaft flanges have a 7th hole drilled and threaded so you can screw in a bolt to pop the shaft loose. You will probably need to pull the axle shafts anyway to do an R&R on the rear brakes.
Rob Peterson 1947 KB-1 LS1 6.0 - NV4500 In progress . . . Former METRO and S-140 Owner |
For parts, I'd start by browsing around the website for Super Scout Specialists, and also check out the other advertisers on here. Locally, NAPA is usually a decent bet. Don't expect them to stock much of anything in the store but within a day or two you can probably get the typical tune-up stuff. There are certain parts which can be a real struggle but if you ask on here (see the classifieds section) you'll find there are packrats around the country that can supply you. These are very practical trucks; I'm no mechanic, but so far I have done all of the mechanical work on my IH all by myself. Keep in mind that, depending on gearing, that truck may not be much good at modern highway speeds. Maybe not a concern, and something you could change if it is.
1967 Impala 283 1974 '100' 258 |
If I was going to look at different parts for my motor to start preparing, where would I look as far as motor parts and carb parts and such? |
I've had fair luck finding some parts at Rockauto. They are easy to deal with and have a very good return policy. http://www.rockauto.com/
Binder Books can also get you the Line Setting Ticket for your truck. Lots of good info on what your truck came from the factory with. The LST might also be taped to the top of your glovebox (the outside- up under the dash). 2 purchases I'll never regret are the shop manual and parts catalog. They'll save you lots of time and money. The shop manual has terrific illustrated step-by-step instructions for almost any repair you can make to the truck. Binder Books has them, but I got my greasy, crusty parts catalog off ebay for about half. Nice find! Can't wait to see your progress Gary
"We can't stop here- this is bat country!" HST '58 A120 3/4 AWD '49 KB2 '55 R110 |
Welcome! I as well am fairly new to this awesome forum. In my short tenure I have had 2to issues that the vast IH knowledge from this group has helped me through expertly. One if the places I have sourced parys from is ihonlynorth.com. I havr just started a build of a 79 scout and found performance parts on the kind of expensive side. But I love my scout as it brings back childhood memories of wheeling on the rubicon. Good luck and again welcome.
79 Scout II 345 727 Dana 44's Spools front and rear, Dana 20 And On The 8th Day God Created Asphalt So Yuppies Can Wheel Also.
Nice cab. Love to see a dually pick-up bed on the back.
Paul Schuh 1972 1210 Travelall 4x4 - 392 / TF 727 / Detroit rear / Lock-Rite front / National springs |
| 1300 , 196 , 1967 , bed , body , brakes , build , clutch , craigslist , diff , find , floor , frozen , hose , international , manual , part , parts , pictures , pto , rear , rusted , truck , wheel , wheels |
| Nice travelall find | michigan scout | Great Lakes Binders | 16 | 07-08-2012 12:38 PM |
| SOA, The drive home, Death wobble solution | DJForrestA | General IH Tech | 9 | 04-03-2005 10:03 AM |
| Furry Friends Need New Home | atlantascoutfan | Old Dominion Binders Association | 2 | 12-27-2003 10:41 AM |
| Diesel Fuel vs. Home Heating Oil | John Donnelly | Diesel Tech | 11 | 10-18-2003 09:12 PM |
| i got my terra home! | Paul "Misterfixit" Schulz | General IH Tech | 7 | 09-21-2003 03:31 AM |
