Old 06-18-2012, 04:17 AM
paukerock paukerock is offline
Default light knob
hi how can i remove the light knob from tha triangulare axel
Old 06-18-2012, 07:44 AM
RobertC RobertC is offline
Default Re: light knob
Assume you are talking about the headlight switch...
Do not know which IH you have, but they are generally "GM" switches.
There is a "push button" on the "top" (opposite from wiring connector).
You turn the headlights on / kmob all the way out; push the button in and hold it down while pulling the knob / shaft out of the switch.
I think the switch is mounted "upside down" on (some?) IHs. If you poke your head under the dash, you can see the "push button" with a flashlight.
I think other switches may have a set screw in the knob - only have experience with "old" GM switches.
To replace; just push the shaft back into the switch.
73 Travellall 1210 2WD, 392, T-34, 3.73 w/stock Trac-Lok
Old 06-18-2012, 08:52 AM
sorry i drive a sccout II from 1977
and i am trying too get the black nob with the symbel for the light of af the axel
the mechanizem is no problem too get of onse the the nob is of i can get it troug the daschboard
Old 06-18-2012, 08:57 AM
Mike Moore's Avatar
Mike Moore Mike Moore is offline
The knob stays on the shaft...there is a push button on the switch behind the dash that needs to be pushed, like Robert said. The knob and shaft pull out of that as an assembly.
Push this button:
And this happens:
Mike Moore
www.ScoutcoProducts.com
______________
1980 Scout II-Chevy LT1, 700r4, NP241, 3.73's, RS, 4" lift, 31's. Daily driver
Scout LT1 swap: $3055
Leaving a riced out Honda with a fartpipe sitting at the stoplight: Priceless!
Old 06-18-2012, 09:04 AM
ok thank you verry mutch now i know the euro haze falen
196 , 1960 , 1966 , axel , chevy , dash , harness , headlights , knob , light , problem , pulling , remove , switch , top , turn , wiring
Help!! Generator Light on Scout 80 Question Cpeters General IH Tech 11 04-15-2005 08:14 AM
Replacement Cargo Light for Terra? Brettm General IH Tech 4 04-15-2005 04:13 AM
Scout II light switch, dome light Blackdog General IH Tech 7 03-10-2005 05:22 PM
another alternator problem :( Lecasta7 General IH Tech 23 04-12-2002 02:41 PM
