Somewhere in Iowa, home of "Missouri Engineering"
![]() I have the sae#4 and a 727 auto adapter here, and would like if possible to use a mustang 5.0 t5, behind it, so... What mods to what, and where did you get them done? Thanks...... Pictures would be nice...... ![]() Dslsmoke
***************************** "High Keeper of the Ancient Archives". |
The bellhousing was already modified to bolt up a chevy trans. I cut around 2 1/2" out, bolted the flanged part to the engine, indicated the trans section to be centered and square to the crank and welded it together. bolted up a Chevy Astrovan diaphragm clutch and S-10 5speed. The trans is a bone stock t-5.
Sorry no pictures.
The sd33/727 was a 440 mopar pattern vs the SV IH pattern in gas scouts.
So the manual swap could be done as described with various manual parts that you can bolt together using the mopar bell housing.
now we know the rest of the story,thx for the info...jeff
![]() If I understand you correctly, this is what I need to buy to be able to install my T5 behind the sd33, with the 727 adapter using the sae#4 flywheel and clutch system, correct? (scroll to the bottom of the page to see the details)...http://www.summitracing.com/parts/QT...ion+Type%7cT-5 If it is really that simple, then I'm in business..... ![]() Please confirm............ Thanks.. Dslsmoke
A stock Mopar bellhousing puts the trans 3-4" too far back & the input shaft won't reach the clutch.
So the manual swap could be done as described with various manual parts that you can bolt together using the mopar bell housing. __________________ Bill USN-1 OK, So I could do the sd33 with auto adapter, sae#4 flywheel and a clutch system, along with this special bell-housing kit to match up my ford T-5. If that works, then it will make things real easy. See what you all think. http://www.summitracing.com/parts/QT...ion+Type%7cT-5 Dslsmoke
Hi! I would like to ask for help. Hungary is a 1980 Scout II T19 gearbox oil should I do it ours?
Thank you. |
| 345 , 727 , automatic , case , crank , diesel , frame , front , part , plug , rear , safety , scout , sd33 , start , starter , swap , switch , terra , tranny , transmission , truck , turbo , wiring , worth |
| Engine/ Tranny Swap for '75 150/ Bucket Seats | bigjojo | General IH Tech | 8 | 12-04-2011 09:00 AM |
| 727; divorced to marries T/C swap | BioTex | General IH Tech | 11 | 08-16-2011 05:49 PM |
| Scout II 727 to T19 swap | gillis51 | General IH Tech | 21 | 12-12-2010 01:20 AM |
| 727 Tranny Not Shifting | mike4514 | General IH Tech | 30 | 04-22-2009 05:23 PM |
| tranny swap?? | Bojon01 | General IH Tech | 2 | 05-13-2003 08:43 PM |
