Charter Member, F.O.P. (Friends of Poseidon) |
What might be a suitable donor vehicle for a front disc conversion? I am guessing an IHC S series hydromax setup for the master, unless the stock hydrovac might be able to handle it. What about a period air-over-hydraulic setup? Yes I know, two systems to set up and potentially fail, but I am looking for ideas here.
When all is said and done, I can't see a disc conversion costing more than all new brake parts for this beast, if available. There are some damn big brakes on this truck, especially the back 4" X 16" type FR.
Measure your axles and frame mounts and head for the truck salvage yards. Grab the master cylinder that goes with the axle.
Doc Stewart "Tough Old Geezer" Charter member: IH Old Hippie Club Last edited by Doc Stewart; 06-14-2012 at 04:31 PM. Reason: schpeling |
Not happening around here. Most were cleaned out by $14+ per hundred. I know of a couple of places that will have 79-88 S series trucks that's why I suggested that idea for a master/hydrovac or hydromax. A 79 or 80 will still have the hydrovac setup ala Loadstar. Otherwise I am just fishing here. I'm not swapping in an axle unless I know it is ready to go. Almost worst case is getting 4 cylinders sleeved for 4 skins, but that still leaves me with brittle old springs etc.
My thought is that the rear cylinders may be the same as on the RA120/126/RA184, which are the same as on a Loadstar, IIRC. Those cyls are available, something like 25 or 30 bucks each. There are no visible casting #s on the cyls to compare, sadly. The axle itself is visually identical to 50s, 60s and 70s 2 speed IHC light truck units. Just the brakes are different. I am sure somewhere I can get kits for the front cyls, I feel more comfortable with new ones. The truck does barely stop but the whole thing needs refresh/refit. I am seriously considering a front disc conversion using a turned down drum as the 'hub'. I am just still totally clueless on the back. EDIT: I guess I could gut the back and do the same thing?????
Well all of the IH caliper/rotor/pad combos I looked at were pretty high. I would likely need to buy a whole truck or bus cheap and strip it. IN the meantime, I was wondering if anyone had a parts cross for the rear cylinders:
75 586 R93 I need four
Well I have a parts update.
I have found several sources for the rear wheel cylinders. I broke down and called Outback Parts because I figured if RJ couldn't get them it was all over. I have found repeatedly in the past that Outback often takes the IH part # and crosses it in one of their resources to find a modern manufactured part that anyone can get over the counter with a significant markup. When he responded immediately that he had them but needed to 'get them in' I knew it was game on. They wanted $89 each for the cylinders, which is not completely a shock to me but I just can't do that. Actually it was $89 plus shipping to him plus shipping to me. Hmmmmmn. Well, after all it is a business. So I did a little more research. I found a post on the YT website where a guy had found a couple of these and posted the part # for help to identify the application. One was actually in a Navistar box so I was intrigued. Called my Navistar dealer 2 miles from my house and found that the number straight from the 1949 MT-68 was still good (!) but was coming up 'discontinued'. They are always good for the cross so he gave me his generic cross # and off I went. Raybestos still listed it as a warehouse order and the part is $87.50 each. Dormans are $65 each.....sounds like we have a winner. I also found someone with 2 NOS cylinders in his inventory for $50 but he hads to do a treasure hunt in his parts room. So while I wait for him to scrounge and rummage and for the YT guy to respond I am going to drag the truck off the farm and onto the hard to break it down to the backing plates. As there is still marginal stopping power I am assuming what I have is at least put together properly. I also found front cylinder kits for $12 each which is not too bad. Also a MC rebuild kit for $20ish can't remember exactly. Spring kits are apparently available. I have also found brake and clutch linings. I just have to measure the inside of my drums to determine if they are 4", 4.5" or 5". I have found that 20" tires have really jumped up lately. 9.00 steers are over $200 and 9.00 drives are over $300. Each. Currently has 10.00 on the back. All in all a decent amount of success this week. Keep in mind this is a worthwhile project as the truck has under 20K miles and has minimal sheetmetal rust. Long term, this is what I will need: intact working dash, this one is fried from 12v. wiper assembly including arms complete pristine windows and regulators. I can rebuild these but why waste time as they are rusty nice seat hood emblem (and maybe a hood? big nose dent) truck T98, T19 or 5 speed with the driveshaft brake (out with the Fuller F-51-C) inner door cardboard and a firewall pad contemporaneous IH dealer roof radio? were they available in 1949? upper grill trim bar needs restoration (has the very rare L stainless grill trim)
| 1950 , air , axle , axles , brake , brakes , conversion , cylinder , disc , frame , front , hydraulic , hydrovac , ihc , master , mounts , part , parts , project , rear , s series , salvage yards , series , truck , work |
