Old 06-05-2012, 12:07 PM
Default 304 engine jet size?
304 factory rebuild, used. Holly 2300 taken off previous , now blown, 392 engine.
What would be the recommended jet size for use at sea level??
Old 06-05-2012, 04:45 PM
Brian Huver's Avatar
Brian Huver Brian Huver is offline
Default Re: 304 engine jet size?
Hey Doc, at sea level that should be a #61 or $62 jet size. If i can remember these are the ones that come factory with the carb.
1973 1/2 Ton Wagon Master 4x4
You can follow my Wagon Master work at the following link:
Thewagonmasterrestore.wordpress.com
Old 06-05-2012, 05:12 PM
Thomas's Avatar
Thomas Thomas is offline
---It depends on the list # and application really. If it were a 1710 (early 266-304) like mine, I would recommend something in the range of #44 to #47, but Holley said they showed #53 was standard when they built it. Largest I have seen on any 304's 2300, which I knew, with absolution, had never had more than basic rebuilding, is #57. I ran it at 350' in MI with no problem, all through elevations on my way to AL, as well as here in WI (#45 because I couldn't find new #44s at the time), where IIRC I read was 850'. In AL, the humidity gave me hell, but it still showed excellent readings on the plugs as well sniffer/detector. Don't forget a new Holley 108-52 (or the Felpro version 60677). There's also reusable (buna rubber) gaskets you can place on either side to prolong use of the 1/4" thick Base Plate Gasket.
---Call Holley to see what they have in their books. You might get lucky & catch someone in partz that knows how to look up the parts list... and just recently someone posted they had snagged an illustrated pats book off eBay, maybe they'll chime in or you can find that thread & ask there. I would base the search on threads made within the last month. Sorry, no history beyond the page I am looking at now on mobile, or I would try to provide you with a link to the thread.
T.R.E.Jr.(Fortiter Et Recte)
53 Farmall H=Heinz
49 IH fridge=?
Who loves hearing,
Old 06-05-2012, 05:55 PM
Thanks, guys. It had 53s. I had a pair of 59s so that is what is in it now. I'll bump it up and see how she runs.
Old 06-05-2012, 10:56 PM
Eric VanBuren's Avatar
List number makes a big difference in the proper jets I've seen and ran 50-53 in my IH spec carbs on 345s near sea level.
Old 06-06-2012, 08:19 AM
Kurt_M Kurt_M is offline
I have the Holley llustrated Parts Guide and can look up stock jet sizes. On the IH 2 bbl Holley there were 2 pretty common venturi sizes used. The small venturi carbs had 53 jets and the larger venturi size used 61. But there are many others mixed in thru that whole bunch. The 1710 carb does show it had 53 jets. Also, keep in mind the jet size is the design of the carb and not so much what engine it is on, the carb doesn't know if the air going thru is is going to a 304 or a 392 the fuel ratio is still the same, with tweaks just for each individual engine.
Old 06-06-2012, 11:49 AM
Greg R's Avatar
Greg R Greg R is offline
Kurt is pretty spot on and sums it best.
If yore burn'in E10, you might find bumping it up 2 sizes from stock will help with ping and drivability.
69 800
266 V8/4spd & D18TC/OD
4.27 D30/ D44
'56 S110 240 I6/4spd
'71 1210 345 V8/4spd 2WD
'67 Travelall BG246/4spd 2WD
Old 06-07-2012, 09:16 AM
thanks guys. Got it running well.
Old 06-07-2012, 09:39 AM
Dave Peters Dave Peters is offline
Doc- What did you end up using?
Old 06-19-2012, 02:47 PM
Thomas's Avatar
---Glad you got it Doc.
Originally Posted by Kurt_M View Post
... Also, keep in mind the jet size is the design of the carb and not so much what engine it is on, the carb doesn't know if the air going thru is is going to a 304 or a 392 the fuel ratio is still the same, with tweaks just for each individual engine...
---Ehhh, sorta. It's true that the carb can't adjust how much air is taken in without human intervention (manually working the choke). The cfm/design determines how much air goes through the carb and the circuitry, power valve & jets determine how much fuel is sucked in. If too large a jet in a carb with too small of venturi (cfm does* matter), it will run lean once the line is crossed for measured air flow and vice-versa. Sure you know that, but I saw somewhat backward, partial information in your informative post that could be misleading. Don't get me wrong, I understood what you meant.
---Glad you had the opportunity to find the HIPG. I purchased if memory serves correctly, a new, mint (not a "remainder"), 5th Edition about 20 years ago & someone 10 years ago or so, apparently needed it more than I. While a vital edition to the library, I haven't gotten round to purchasing another. When that sort of thing happens, Say they cost $60ea new, I would only justify buying another if the total price paid for both was equal or lesser than one new. Yes, when it comes to stolen tools I am often conservative ~shrug~
---If you hadn't seen/heard already, I believe Doc said #61 in another recent thread.
53 Farmall H=Heinz
49 IH fridge=?
Who loves hearing,
2300 , 304 , 392 , air , blown , bump , carb , carb. , difference , ebay , engine , find , fuel , holley , number , parts , power , rebuild , search , show , size , travelall , valve
Silver/Black/"BG" Diamond engine ID and information John Donnelly Triple Diamond Trucks 36 08-24-2012 02:23 PM
quadrajet jet and primary rod size question for a 392 sdowney717 General IH Tech 6 11-25-2010 07:49 AM
Factory size main jet for BG241? EagleFreek General IH Tech 7 02-14-2010 04:42 PM
Size engine Brian Huver Triple Diamond Trucks 2 02-02-2010 12:32 PM
1968 1200C 304 engine... flat top or contoured pistons? R.Smith General IH Tech 4 07-25-2007 05:26 AM
