If it was a metal tank I wouldn't worry. But with a poly tank it might not be a bad bit of caution. Get a good dingle berry that flies on top of the tank I doubt would cause any sort of fire, but could damage the tank.
Kind or also depends on where you're welding, how you can shield things, and how good of a welder you are (i.e. how much sparking or other issues you might have). |
Just think, if something bad were to happen, you would be wishing you would have taken the extra time to drop the tank. You will get a better repair and remove the hazard of fire, explosion, or melting your new tank.
1977 Scout II, 304, 727, DANA 44/44/20, "BUSTER" 1960 Travelall, 4X4, 3/4 ton, "WILBUR" ![]() Sully |
When I weld near something that I don't want hot sparks landing on I soak an old towel and drape/hang it to protect the surface from sparks.
But, as I am sure you do being a fireman, always keep a good fire extinguisher close at hand... Darrell |
Being a welder myself, I also say just take the time to pull the tank. I personally wouldnt risk it. It could end up costing you a new tank if you burned a hole, then youd have to pull it anyway
I need a scout ii top bad if you have one pm me |
My good friend Dennis was killed 7 years ago at age 36 cutting brackets out of a ventilated 50' boat engine bay that he was repowering for a customer. He wasn't even real close to the water filled gas tanks when the whole thing exploded. The engines had to come out before they could cut out the tanks.
He left a wife and 5 young children. Remove the tanks before you get close with a torch or welder. That's my opinion.
Charter Member, F.O.P. (Friends of Poseidon) |
With a plastic tank, go ahead and pull it. With my truck, I would just top both my tanks off (IH powered Ford).
How hard would it be to rig yourself up some shields out of sheet metal? Something (or things) to fit in those tight areas and provide a good, temporary barrier between your work surfaces, and the tank and fuel lines? It could be held in place by bailing wire or similar. Even welding magnets.
Patrick Morris, KI6VSM 1978 Scout II Traveltop (owned it since 1991) 345-V8, 4-spd, D300 TC, rear Powr-Lok diff'l 3" SJ lift, 31" General Grabber AT2s |
A shield wont stop fumes
| 800 , binder , car , cutting , engine , ford , fuel , fumes , gas , gas tank , hose , hot , remove , repair , sale , tank , test , top , tre , truck , water , welding , wheel , work |
| 1963 C1100 Gas Tank needed | Snorty | General IH Tech | 4 | 02-27-2012 02:28 PM |
| Gas Tank Replacement | bdgn01 | General IH Tech | 3 | 08-05-2011 05:16 AM |
| Scout 80 gas tank removal...How? | scout-ED | General IH Tech | 13 | 01-12-2006 09:00 AM |
| Can't get gas from the tank to the fuel pump | Mernjohn | General IH Tech | 7 | 09-12-2004 05:46 PM |
