I believe the internals are the same, nothing IH specific. In all the research I once did on 727 rebuild kits all I discovered was that not all kits are equal. Some come with more parts than others, some offer better clutches and so on. I would say that if you havent built a 727 or other AT before it would be a good idea to do lots of research so you know exactly what parts you want in your kit
1980 SII, 345, 727, D20, 1977 Terra 304, T-19wr, D20 |
Trans are the same with basically the same year breaks for the internal changes.
I use the ATSG and the 727 book from Munroe. You can get both on Ebay. Along with a complete master rebuild kit. Normally much cheaper then PATC for the kit. I have bought many specialty items from PATC when doing hop up mods to the trans like the servos upgrades. I normally opt for all the steels and bushings when doing an unknown trans. I also include a programming kit in all of them. Normally the Transgo TF-2. i also use the deeper 618 pan w/filter extention and reuseable gasket.
Yeah, im beginning to think EBAY is the place to go, but Bill usn-1 that transgo kit appears to be a full manual valve body, have a reccomendation for one that still allows me to throw it in drive and let the tranny do the rest?
Nope...TF-2 is what you want.
| 727 , body , box , case , clutch , dog , ebay , engine , filter , ford , gasket , international , manual , master , mopar , overdrive , parts , question , rebuild , rebuild kit , scout , shavings , tranny , transfer case , work |
| Replacement 727 Transmission Question | jmd2000 | General IH Tech | 3 | 05-11-2012 08:11 PM |
| Help, 727 torqueflite question | B.C.Ries | General IH Tech | 15 | 04-21-2006 02:30 PM |
| scout II 727 question | JakeCL | General IH Tech | 2 | 06-07-2005 10:55 AM |
| 727 AT shift cable install question | Matt G | General IH Tech | 2 | 05-27-2005 11:47 AM |
| auto 727 water resistant question? | Duly | General IH Tech | 7 | 09-15-2003 10:11 AM |
