Old 05-30-2012, 06:41 PM
RJJP RJJP is offline
Default T53 Transmission
Does anyone here have any information on the T53 OD Transmission, the one I found currently resides in a 66 R185 Fire truck with a 501 I6...
I'm mainly interested in gear ratios, weather it's partially/fully synchronized or not, and how much torque it can handle.
Thanks for any help.
Old 05-30-2012, 07:26 PM
Eric V Bielke's Avatar
Eric V Bielke Eric V Bielke is offline
Default Re: T53 Transmission
Do you mean T35 ???
Old 05-30-2012, 08:09 PM
On the little card above the visor it says "T53 OD Trans"
It's a five speed.
Old 05-30-2012, 09:58 PM
john breeze john breeze is offline
t53 is a 5-43 fuller transmission and the rd501 puts out 451 pounds of torque and 210 hp at least thats what the old book i have says.
Old 05-31-2012, 09:15 AM
Not a good choice for any of the Light Line trucks as it is HEAVY! and bulky. For an OD trans in a pickup or Travelall, - won't work in a ScoutII - seek a T34 five speed with gear ratios starting at 6.2 for first and a .2 OD for fifth. You will need the bell housing to go with it. Also, be aware that the gap between 3 and 4 gears is big which can be annoying in the hills especially when towing loads.
My suggestion is to keep your trans and change your diff ratio.
Old 05-31-2012, 12:12 PM
I was thinking about it rather than a ZF5 in a F250.
Old 05-31-2012, 04:04 PM
The F250 would handle it but I have no idea what is involved to swap.
Old 06-01-2012, 06:53 PM
Thanks for the help y'all... Can't find any info on a 5-43 fuller either, but I'll keep looking.
Old 06-02-2012, 09:59 AM
i have a old MOTOR repair manual that is my dad's. the newist truck in the manual is a 77. it shows how to rebuild it, but no gear ratios sorry
bell housing , book , can't find , choice , diff , find , gap , gear , gear ratios , gears , info , light , pickup , rebuild , scoutii , starting , swap , torque , towing , transmission , travelall , truck , work
Automatic Overdrive Transmission For IH V8s MikeInMobile,AL BP IH Knowledge Wiki 0 02-20-2009 09:51 PM
Loose Transmission mount SCscoutguy General IH Tech 10 10-26-2006 07:26 AM
replacing clutch: pull engine or trans? igrout General IH Tech 13 01-17-2006 06:57 AM
Don't use Gear oil in your manual transmission - The sermon by brother Eldon! John Donnelly General IH Tech 0 11-29-2005 01:01 PM
