Old 05-29-2012, 12:07 PM
gwinter1129's Avatar
gwinter1129 gwinter1129 is offline
Default Next Question, 304 upgrade or not
My 71 800B has the original 304 engine in it. It is being rebuilt and my question is - the terminals on the starter are broke off so should I upgrade to the hot one or go with original, should I upgrade the coil, distributor and the carb? If I should upgrade what suggestions do you have?
Old 05-29-2012, 03:11 PM
Default Re: Next Question, 304 upgrade or not
Keep your starter. Replace your solenoid. Delco part. NAPA has them. These low compression V8s don't need a hot starter.
Any old coil works on these engines.
Up grade you existing Dizzy with a Pertronix or modify a salvage yard HEI dizzy - do a search.
There is not much to up grade in the carb department. There is a Weber that will work but I have never used one. Rebuild your 2300 Holly 2bbl and drive it another 50,000 miles.
Reasonable up grades:
Better cam - call IHONlyNorth for a cam
Better valve seals
Polish the oil return passages while doing some minor porting on the head.
Bigger valves are not necessary - IH SV8s only rev to 4K unless you do extensive modifications.
Dial in the cam accurately. No need to change or replace timing gears.
2300 , 2bbl , 304 , 800b , broke , cam , carb , coil , compression , distributor , engine , hei , hot , part , pertronix , question , rebuild , solenoid , starter , timing , upgrade
Exhaust manifold bolt size question 304 SV 67Binder General IH Tech 7 04-11-2009 08:45 PM
carb question 1972 scout 304 Lees1972Scout General IH Tech 19 06-10-2008 11:33 PM
Brand New Rebuilt 304 question mclark General IH Tech 26 04-08-2008 09:14 AM
304 E question clint larson General IH Tech 3 01-30-2008 10:29 AM
304 Swap question RonG General IH Tech 0 05-08-2005 10:28 PM
