That rod connects to the switch as you said, the switch is adjustable. Mounted on the top of the column under the dash, 2 screws need to be loosened and the switch will adjust up and down the column. That should fix your problem, if it does not the gear and rod asembly in the column may be worn out, but try adjusting the switch first.
By the way welcome to the forum!! Ron
Ron Mc. Nebraska 1974 IH Scout11 1975 IH Scout11 1965 IH 1 ton pickup-sold |
Thanks Ron. I will try adjusting it. However, I think the gear may be worn. The key has some resistance at first and then suddenly is loose. How do I remove gear and rod and where can I get a new one?
Thanks again. |
Well it's a Saginaw column Any "good" parts store should be able to get them. Just find a parts store that is willing to look it up in a book not a computer. I am sure any of the vendors listed here on this forum would be glad to help you also.
Here is IHON:http://www.shopih.com/SL422311C1-p-CP.html Ron
Thanks again...I just ordered it!
Moved to Tech so it's easier to find and since it's not a project thread.
| 1974 , 345 , broke , column , engine , first scout , gear , help! , ignition , key , parts , project , scout , scout ii , screws , start , steering , steering column , top , truck , turn , wheel |
| Hillbilly Harvester | gmbarker78 | Southeast Binders Association | 168 | 10-28-2011 05:03 PM |
| TBI Sudden No start issues... I'm Stumped | jcal73 | Injection Tech | 5 | 02-06-2011 03:41 PM |
| Having Problems Getting Engine to Start. | zrb888 | General IH Tech | 6 | 11-12-2006 09:41 PM |
| Engine Swap | ff6j6100 | General IH Tech | 10 | 10-08-2005 09:44 PM |
| Engine won't start | egdinger | General IH Tech | 5 | 10-03-2004 04:41 PM |
