Also, is there a "short list" of ALL parts with part numbers for NEW items already compiled that I can just print off for IH FULLSIZE conversion? Thanks for pointing me in the right direction.
68 Travelall 4x4 Do-It-All-Rig: 392V8, T35, NP202, 4.11's, 14B, HD D44, 4" Lift, 4W Disc, H2's with 34.5" BFG AT's (Ongong project...) I can remember when the only carbs anyone cared about were under the hood!
72 Scout II - Flame Red Built 304/TBI-7747/727-TF2/D20-Twin stick |
________________ 75 Scout II-Jacy's Scout 77 Scout II Crawler- RIP The thing I love about a mullet is it doesn't just happen. You make that choice! ![]() No, The guy in my avatar is not me! Ain't he cool though?
The confussion is normally in the use of "return" line.
The HB has a pressure in and a pressure out and a return which is the smaller barb fitting. the "return" should always go thru the straight portion of the T with the PS return on the leg of the T. Also use the preformed brass T from the sprinkler section of your home store and not a standard brass NPT- T and fittings screwed together. The ID is a little smaller on the NPT fittings.
Here's a better diagram. It's directly from Bendix Tech Manual. (Disregard the Master cylinder hookup. The front brakes may be the back connection on the one you use)
![]() The PS box always pushes fluid through the return, you don't want to block or create back pressure by running it into the wall of the "T" fitting. The hydroboost only returns fluid when the brakes are applied. Additional Bendix troubleshooting/repair documentation is attached. Additional diagrams are included.
All right Jauringer.... I see how it is. You just couldn't let me be proud of my awesome technical diagram!
Seriously though, thanks for the better pic. That should help people a lot more than my half arsed attempt at technical drawing.
Especially if you run a cooler, like I do. I just did this last week. I made two mistakes. First, the HB ran to the "straight through" side of the T, and second, I THEN put the cooler inline before it went back to the pump reservoir. I may have had better luck with the T at the end of the line, just in front of the reservoir - I didn't think it mattered at the time, but it does. I eliminated the T by running the HB directly back to the pump (I welded an extension on the pump neck with a fitting on the side) and all is well. How did I determine it was "wrong" you ask? With the engine off, I could push the Scout. Turn the engine on, and the slight back pressure from the steering box and coolers would cause the HB to auto-apply. I thought they were dragging.. but when I drove it out of the shop into the slightly sloped driveway, and it sat still idling in neutral, then shut it off and it immediately coasted forward I KNEW I had a problem, and it was the hydroboost. Fortunately, a quick re-route and I was in business. So, either try the "T" with the straight-through on the steering box, OR put the cooler before you T the HB return in, OR best yet, just run the HB direct to the reservoir.
We Race Farm Equipment M4x4A #576 KE7VUX |
Per the write up....
The cooler goes on the PS side only. Adding it to the HB line only adds more resriction to the return line and causes the HB to apply the brakes on it's own!!! Why put a cooler in a line your trying to reduce the restriction on by routing it on the straight side of the T? it's all been covered! Every wrong way to install it has been done. ![]()
I thought I would make it better by installing a cooler. I've run front lockers before with power steering and always add one (and now two!) coolers. On this Scout, I have lockers front and rear, wide tires, hydroboost, power steering, oh, and hydraulic assist to all make the power steering fluid hot and smokey. I did not, however, have a good idea as to where the cooler should be installed in the line - I'm not used to having so many return lines all over the place.
| bendix , binder , binderplanet , box , brakes , conversion , cooler , cylinder , diagram , fittings , fluid , front , hoses , hydroboost , manual , master , parts , problem , repair , routing , search , short , show , steering , tire |
| Big thanks to Bill USN | 46binder | Injection Tech | 1 | 03-15-2012 07:46 PM |
| Paging USN Bill | Robert JetFxr | Injection Tech | 6 | 01-18-2010 08:05 PM |
| Hydroboost issues - what's inside? | aecavender | General IH Tech | 13 | 06-16-2006 05:00 PM |
| Doug, Bill, Hydroboost guys - I wanna ask ... | David Dixon | General IH Tech | 6 | 01-14-2005 08:21 AM |
