Go Back   Binder Planet Forums > IH Clubs > Member-Club Forums > Gulf Coast Binders
Old 05-23-2012, 03:26 PM
ihscoutfanatic ihscoutfanatic is offline
Default 727 crash course - Sat May 26th
Got the rebuild kit in so the transmission rebuild for Saturday is on for.this weekend. The plan is to pull the trans Friday and rebuild all day Saturday. Anyone who would like to come is more than welcome just PM me and ill send you the address and directions. I'll probably start the teardown around 9-10 am Saturday. I don't think I would call it a wrench day since its mainly all bench work but if you ever wanted hands on experience with the internals of a 727 before you go at it yourself then come on down.
Roof (rōōf, rŏŏf) - the external upper covering of a house or other building. The top covering of something: the roof of a car. - I dont get it. What are these for again?
79 Scout 2 SOA Daily Driver - 345/727tf/D20/D44's
1961 IH Metro - BG241 - T-98 - work in progress
Old 05-23-2012, 05:26 PM
Default Re: 727 crash course - Sat May 26th
I dont know if this is in the instructions,but my Dad(mechanic over 50 years)always soaks the clutchs in tranny fluid at leat for 24 hours.
Old 05-23-2012, 05:33 PM
Might not be a bad idea. Couldn't imagine it hurting anything ill do that tomorrow. Thanks for the tip Jeff
Old 05-23-2012, 07:19 PM
Fred Demmon's Avatar
Jeff is 100% correct
It is crucial to soak them prior to installation
You will want to soak the bands also.
You don't want to use the red "shop towels" the red fibers can cause problems, use the paper shop towles.
Did the kit come with both bands or just 1?
President
Gulf Coast Binders
75 SII 304 4 speed
65 80 152 3 speed
77 SII 345 Automatic
75 SII NO engine or trans
74 SII 196 4 speed
76 SII 196 4 speed
80 SII turbo diesel 4 speed
Old 05-23-2012, 07:23 PM
jtl1100's Avatar
jtl1100 jtl1100 is offline
Good luck guys.
Old 05-23-2012, 07:35 PM
Came with just the kick down band. I actually don't think my bands are bad but pretty sure my clutch packs are toast since it shifts great but slips once in gear but I'm gonna for sure install the new kick down band.
Old 05-24-2012, 05:11 PM
scoutpappa's Avatar
scoutpappa scoutpappa is offline
Something will happen.
Old 05-25-2012, 06:36 AM
It will be have a feeler gage handy to check the clearance on the assembeled packs.
Plus a rubber tiped blow gun to pressure the servos and clutch packs to ensure they are working correctly
President
Gulf Coast Binders
75 SII 304 4 speed
65 80 152 3 speed
74 SII 196 4 speed
76 SII 196 4 speed
Old 05-25-2012, 07:03 AM
Erik Morton's Avatar
Erik Morton Erik Morton is offline
Wish you were closer! That sounds like a very instructional day.
Erik K. Morton
'79 4" Skyjacker, 31's, "The Other Woman" Not rust free but a lot closer than it was.
Old 05-25-2012, 10:40 AM
sullyscout77's Avatar
Weston,
Check your other post for "SpareTF727". Guess I been responding to the wrong one.
See you around 9am!
Sully
100 , 727 , clutch , fluid , gage , gear , kick down , kit , question , rebuild , rebuild kit , red , rubber , scout , shop , start , tranny , transmission , wanted , work , wrenching
Odd 727 Behavior (long) scoutboy74 General IH Tech 131 06-01-2012 08:17 PM
Conpare Chrysler TF 727 Internals With IHC Guts M. Mayben General IH Tech 49 06-13-2011 07:44 AM
Big Rig Snow Run, Sat Jan 26th! binderbound IH Scouts & Trucks of Oregon 30 01-28-2008 02:55 AM
727 4x2 to 727 4x4 bigjohn General IH Tech 2 02-10-2005 05:26 PM
