I'd say there would be no problem doing it that way. You're right...either seperating the fluid at the pressure switch or at the axle. The only real "issue" I see is that you'll have that one additional rubber hose that could be prone to breaking/damage/whatever.
-Gary
El Guapo: Jefe, would you say I have a plethora of Scouts (and two Travelalls and a Pickup)? Jefe: Yes, El Guapo. You have a plethora. |
Okay, so I opened up the holes on the M/C, made a spacer plate to cover up the gap around the base of the new cylinder (the old one was bigger), installed the switch block, made up my brake lines and now there is a clearance issue with the heater blower. Has anyone else run into this? I suppose I could shim it up with some spacers or something, but then the vertical hole won't line up. Is there a different master that wont have this problem?
I don't think so. But there is plenty of space under that hood to shim the heater box.
I did this upgrade with a slightly different MC and had the same clearance issue. My solution was much less elegant as I just notched the ducting on the heater box to fit the new MC.
Ernie Elkin, NC '63 Scout 80, 152 4cyl, Holley/Weber 5200, Pertronix Ignitor w/Flame Thrower Coil, Rebuilt T-90 3spd, D-18 twin stick T/C, Frt D27, Rr D44 w/PowrLok 4.27s |
| 80 800 brake master , 800 , advice , axle , brake , brakes , bulkhead , dash , differential , firewall , flex , fluid , front , heater , hose , hoses , piston , scout , shim , shop , stalling , switch , upgrade , wheel , work |
| Ignition Upgrade? | 1977ScoutII | Hill Country Binders - Central TX | 40 | 09-23-2007 07:50 PM |
| Scout II/ Scout 80 | 73RustBucket | General IH Tech | 9 | 05-27-2004 12:26 PM |
| Scout 80 MC upgrade | Houston | General IH Tech | 1 | 05-21-2004 12:07 AM |
