Any help on troubleshooting this problem would be appreciated! |
Have you checked your light switch to see if it has a short in it?
And for the inop blinkers, first make sure you have power going to the switch, then from the switch to the blinker relay. It could be something as simple as a bad blinker relay or a bad fuse, it could be something as aggravating as a bad column switch. If you don't have a good digital multi-meter, I would suggest picking one up and letting the fun begin.
78 Scout II Rallye Terra Cotta / Parchment Interior |
Is your hazzard switch pushed in? What kind of vehicle? Scout,travelall??
It sounds like it is in your switch. A quick test would be to unplug the headlight switch and see if they go out. If they do, its in the switch.
Rob 76 Scout II 345/700R4 Auto/Dana20 Dana 44 F/R Hardtop/Soft top ![]() 67 Scout 800 152 stick to be modified Hardtop/Soft top (soon I hope)
78 Scout II. Thanks for the suggestions. I will check my light switch. Would a bad light switch cause the interior courtesy lights to be on?
I believe if you turn the knob all the way counterclockwise it will turn the courtesy lights on. It has been so long since I've turned mine on that I'm not 100% sure on that to be honest.
| battery , broke , cable , can't find , column , dash , electrical , find , front , gauges , grounds , harness , headlights , horn , lights , parts , plug , problem , question , starting , tail , turn , wipers , wiring , wiring harness |
| Hot starter issue or bad battery? | LoneStarScout | General IH Tech | 10 | 10-02-2009 11:34 PM |
| Jumpy Ammeter, Flickering Lights | surfcraft | General IH Tech | 31 | 08-15-2009 03:05 PM |
| Update-No stop lights and hazards but now have signals | WarrenG | General IH Tech | 3 | 08-25-2006 01:43 AM |
| Battery Ground Cable Metldown | Jim | General IH Tech | 7 | 08-03-2006 01:01 PM |
| Dual battery setup | Smithflyfisher1 | General IH Tech | 14 | 10-16-2005 10:15 AM |
