Old 05-22-2012, 10:31 AM
db1115's Avatar
db1115 db1115 is offline
Default 800 Bellcrank to Firewall Cover Seal
Anybody have any idea what IH used (or what I could use) to seal this area beteween the bellcrank clutch relay linkage flipper flopper thingy and the firewall/cover? Thanks in advance.
Davis
Old 05-22-2012, 11:19 AM
fredsterra's Avatar
Default Re: 800 Bellcrank to Firewall Cover Seal
Part of an inner tube? Or modify a large trans shift boot?
Mark Fredrick
Madisonville Ky
Old 05-22-2012, 11:25 AM
db1115's Avatar
I like the idea of a boot Mark. I would need to figure out some way to allow the rod to turn inside the boot. Hmmm. Thanks...please keep the ideas coming.
Davis
Old 05-22-2012, 11:51 AM
Nevada S. Smith's Avatar
Nevada S. Smith Nevada S. Smith is online now
Send a message via AIM to Nevada S. Smith
Default
Davis, super scout specialists shows a clutch pedal linkage seal for $3 and it looks like a rubber donut/grommet type seal-application stats that it is the seal for a 800 with mechanical linkage-I found it in the 80/800 section under clutch I believe. I don't know if this is what you need, as my 800 has a hyd. Clutch. Hope this helps.
Sent from my DROID BIONIC using Tapatalk
Nevada S. Smith
79 SII 345//727/D20
77 SII 345/727/D20
77 Terra 345/t19/D20-Parts Rig
67 800 -four banger w/3spd
"Drive it like you stole it!"
Old 05-22-2012, 11:59 AM
db1115's Avatar
Thanks for the help Nevada. But thats the seal that goes on each end of the rod to seal off the plastic bushings. It wont work for here. Thanks again though.
Davis
Old 05-22-2012, 02:07 PM
scout 66's Avatar
scout 66 scout 66 is offline
What about using a door/trunk gasket, could push it right on. You might have to make a small plate on the firewall side to round out the hole? Should seal it up and look nice. Friction shouldn’t be noticeable on the clutch pedal.
Brant
Old 05-22-2012, 05:49 PM
db1115's Avatar
Brant
That might work Brant. I need to look around and see if I can find something similar to that. Thanks for the suggestion.
Davis
Old 05-22-2012, 07:24 PM
how about a clutch cable cover-800,firewall mounted? you could even bend the cover to fit,cut the hole out a bit bigger also.jeff
File Type: jpg scout 800's,clutch cover,grille,fender 003.jpg (418.0 KB, 14 views)
Old 05-23-2012, 07:24 AM
Mitch Neal's Avatar
Mitch Neal Mitch Neal is offline
Not to hi-jack Davis's thread, but was there nothing there originally? My parts book is not readily available, but surely it list something to fill that gap.
Old 05-23-2012, 07:32 AM
db1115's Avatar
Thats no hi-jack at all Mitch and was part of my original question. There was no remnants of anything at all on the cover, firewall, or bellcrank. My thoughts were exactly like yours...surely IH had something there. It would have been a wide open door for heat, wind, fumes, and critters when these scouts were brand new. But maybe thats why they moved to a cable on the later V-8 800s.
Davis
800 , book , boot , cable , clutch , door , find , firewall , gap , gasket , linkage , mechanical , part , parts , pedal , relay , rubber , scout , seal , steering , super scout specialists , tube , turn , water , work
1970 800 A power steering captchee The Skunkwerks 19 12-27-2011 08:08 AM
Started replacing 73 Travelall tailgate window seals All_Travelall General IH Tech 11 09-14-2011 10:32 PM
car cover for scout 800? Allen Jenkins General IH Tech 9 04-22-2010 07:07 AM
diff cover seal TxScout General IH Tech 3 03-26-2002 05:55 AM
800 Liftgate Seal Pic George Womack General IH Tech 1 11-16-2001 12:55 PM
