Josh
The only thing my Father ever gave me was a Hard time! |
Your 727 has a different case than the chrysler ones,they will not bolt up to the engine
Can you put the guts into the IH case?
Bill talked about doing it in this thread a while back but I don't think he ever actually did it. You would have to get all of the parts from a newer 727 and rebuild your IH case with them.
http://www.justih.org/Binder-Bench/s...ead.php?t=2958
John Godfrey SEBA Member |
I just talked to the transmission guru around these here parts and he said stick with the non lock up! He said the lock up converter was not as strong for pulling and off roading, however it would save some on gas. lol Now I did not ask about swapping the gear sets out, I might ask that when I drop mine off to be rebuilt.
This sounds like a cool option, I am sure you can get an upgraded converter for these transmissions that will handle anything and IH motor can put out. Check out TSR Transmissions or PATC transmsissions. A lock out option would be cool.
The Carl Monroe Book says that all 727 came with the same gear ratio. There is no such thing as a low gear 727. I have heard that a couple of companies make an aftermarket kit but nothing came stock with a lower gear ratio.
| 1977 , 1978 , 345 , 4 barrel , 727 , aftermarket , binder , case , chrysler , gas , gear , kit , lock , low , parts , pulling , question , rebuild , scout , scout ii , show , transmission , wide , work |
| Odd 727 Behavior (long) | scoutboy74 | General IH Tech | 131 | 06-01-2012 08:17 PM |
| Conpare Chrysler TF 727 Internals With IHC Guts | M. Mayben | General IH Tech | 49 | 06-13-2011 07:44 AM |
| IH 727 planetary pinions | ScoutmanSV | General IH Tech | 5 | 08-07-2005 07:57 AM |
| 727 4x2 to 727 4x4 | bigjohn | General IH Tech | 2 | 02-10-2005 05:26 PM |
