Is there a source where they can be had for the right price? Is it worth it or should I just use a lower bearing on the top after it's filed down? My driver's side is the bad side, do I have to do the passenger side too? Are there differences in the pass side and driver's side bearings or can I just order 4 new bearings and get to work? I've never messed with kingpins and I hope I'm not getting in over my head. A local truck shop quoted me $700 for both sides including an alignment if I brought the parts. thanks, Randy
GSA 1968 Travelall 1100C with barn doors, PTO winch, skid plates,T-98, and a BG265. |
Not a difficult job. Just replace the bushing with a taper bearing like on the bottom. Don't file the pin, machine it, or have it done. Jeeps came with an upper bearing.
'67 1200B 4 X 4 T'all V345 T36 OBA "Not much for pretty, but hell on tough!" |
Have you removed the steering arm yet to check the shims or are you just going to tear it all apart and replace anyway?
No, I haven't even gotten as far as taking the wheel off yet. I'm researching and brainstorming before I tackle it.
All suggestions appreciated
Should I do both sides at the same time? If I can just do the driver's side I'd be a happy camper, but if it's correct/necessary to do both then I will.
Are there different parts for each side or will 4 of the same bearings do it? What do I need to look for with the shims? Anything else to look for or avoid?
Here are the unobtainable bushings.
http://www.ebay.com/itm/Dana-Spicer-...=170846298900/ |
| alignment , axle , bearings , bronze , bushing , ebay , find , front , hard to find , international , parts , price , shop , steering , top , travelall , truck , wheel , work , worth , wrenching |
| What bushing is this? | jiman23 | General IH Tech | 9 | 04-11-2011 01:28 PM |
| towing travelall with tow bar: is it safe? | mikem | The Truck Stop | 11 | 04-22-2009 09:22 AM |
| Pickup and Travelall Model Designations (1950 - 1975) | Will Marsh | BP IH Knowledge Wiki | 0 | 02-21-2009 01:54 PM |
