Old 05-08-2012, 02:17 PM
ikavo ikavo is offline
Default light underhood fuel ? spray
Folks,
1980 sd33t - just bought it. Under the hood, I noticed a bunch of blackish looking marks. pretty light at first. They started just over where the AC belt runs, so i figured maybe the belt was throwing off dust.
Then, I noticed that it got more, and moved closer to being over the injection pump. At the same time, I noticed some runs in the staining where it ran down the curve at the front of the hood, so the spot expanded back towards the injection pump, and forward towards the grill.
Anyone else seen this? I figure maybe a fine diesel mist is hitting the hood, and then dirt is getting on it, turning it black. But, I have no idea how to figure out where it's coming from. It doesn't seem to happen at idle or even if I rev the engine with the hood open.
But, i don't want to leave it alone, because if the fuel lines are going bad, inevitably I'll be stranded.
Any help would be welcome,
Ikavo
Old 05-09-2012, 09:47 PM
Default Re: light underhood fuel ? spray
Folks,
In the spirit of adding to the database, I believe I've isolated the fuel mist/spray to the fuel filter mounted on the injection pump, or the feed line too it.
So, I wrapped both in foil, and intend to see which piece of foil gets messed up.
Kinda hoping its the fuel fileter, since I know what to do about that (new gaskets).
Will report back more later....
Ikavo
Old 05-10-2012, 10:11 AM
scoutjones's Avatar
scoutjones scoutjones is offline
Mine sprayed a fine mist (and eventually a geyser). It turned out to be the fuel return line from the filter housing to the tank. The PO had spliced in some rubber fuel line on the tank end. When they tightened the fuel tank, the line was squeezed flat between the tank and the bottom of the bed. There was no relief for the pressure built up in the system. It was an easy fix!
Good luck and welcome!
Old 07-05-2012, 07:33 AM
Default Was: Re: light underhood fuel ? spray; now: Hoses - any one got any they're not using
Folks,
I posted earlier about light underhood fuel spray. It turns out it wasn't a fuel return issue, it's those 32 year old hoses. Running the engine with the hood open, I could see the thick hoses from the lift pump part of the injection pump to the fuel filter, and from the fuel filter to the injection part of the pump sweating.
I need to get new hoses, but no-one in Durango makes them. Does anyone have the hoses I'm talking about, even rotten, so I can send them away to have new ones made? I can't send mine out, because then I wouldn't be able to get to work!
Any help or other ideas would be welcome too...
- Ikavo
Old 07-13-2012, 11:11 AM
Sorry for a duplicate post, but wanted all the related threads to have the relevant information:
These hoses are available from
Titan Equipment, in Colorado Springs
Discount Forklifts in Miami
Kranlyft in the UK (kranlyft.co.uk).
bed , colorado , diesel , engine , filter , front , fuel , fuel filter , fuel line , fuel tank , grill , hood , hose , hoses , idle , lift , light , part , pump , rubber , sd33 , sd33t , tank
Will's Fuel Woes Solved? W.James Diesel Tech 1 11-03-2011 08:11 PM
Odd 2300 Holley problem. Gun Line General IH Tech 40 07-12-2009 05:50 PM
International Diesel Engine fuel question rebelscout Diesel Tech 12 02-13-2007 09:25 PM
One way to Fuel Inject a 4 Cyl!! Bill usn-1 Injection Tech 5 02-02-2007 11:14 AM
Fuel drain back, hard starting Drex General IH Tech 4 06-09-2004 11:45 AM
