Old 05-07-2012, 01:15 PM
scorp1us's Avatar
scorp1us scorp1us is offline
Default Clean way to mount GM spark coil
I figured out this weekend that if you take some 3/4" square stock from HD, and cut it down to length (measurement escapes me, but width of coil + space for the 3/8 bolt) then cut it along its length, the bottom transformer core will fit nicely inside. Drill some holes for across to secure the coil to the mounting (#8screws). Then you'll want to eliminate the walls for where the 3/8 bolt goes. I left a little wall material for rigidity, and just ground the sides of a washer flat to fit, then I bolt it all together and into the old bolt hole for the spark coil.
EDIT: pics coming.
1980 Traveler 345 D44, 3.73, 727, 4" RC SUA w/4* shims, GM 350 TBI (16197427)
clean , coil , ground , mount , screws , spark
Duraspark Distributor Prep taklbury Injection Tech 13 02-09-2012 11:31 AM
No spark please help!!!!!! harvesterman93 General IH Tech 25 01-22-2011 07:58 AM
IH-Prestolite distributor to Ford Dura-Spark II by Thom Singer Bill usn-1 Injection Tech 26 08-27-2010 12:42 PM
Coil voltage fluctuates. Idle fluctuates correspondingly Bread General IH Tech 26 02-08-2008 12:58 PM
Fuel no Spark grimlock97 General IH Tech 8 09-23-2007 09:46 PM
