Was able to get the bent u-bolts out of the pinion yoke, the slip yoke off, clean out the "slime" in it, and find that the yoke is cracked/missing metal on the ears..... I can't get to the bolts in the yoke on the transfer case. Can I remove the trans mount and crossmember to do this? Do I just support the trans with a jack while I have the crossmember off? The driveshaft has a weld on it (see pic), was this done to balance it??? Also, any recommendations on a replacement trans mount?...Poly/Rubber/RPT?? Thanks! 1980 ScoutII/345/727/D300/D44s |
Hey Scooter, if your talking about the bolts for the u-joint on the transfer case (front) I aways reached in from the back over the transfer case. You can only do 1 bolt at a time, so each bolt you have to turn the drive shaft. Tight fit but it can be done.
Ron
Ron Mc. Nebraska 1974 IH Scout11 1975 IH Scout11 1965 IH 1 ton pickup-sold |
The easiest way I know of is to buy an offset box wrench, put it in your vice, heat it up and bend it to the shape needed to clear the crossmember. Or, cut the head off the wrench, bend a steel bar to shape and weld it to the box head
Its a one use tool but it works and you'll be glad you have it when it's needed
1980 SII, 345, 727, D20, 1977 Terra 304, T-19wr, D20 |
I have used a offset boxend wrench. It is tight put the t-case in nutral and turn as needed from the rear.
Thanks.
How would I replace the transmission mount then? and any recommendations on a replacement? Have heard mixed reviews of the RPT mounts.... |
I used the poly style of the OE. (Automatic 2 speed T/C)
Pretty simple. Unbolt and used a floor jack just enough to get the top bushing out. Be careful with the sleeves between the bushings and bolts. It took less than an hour. It's the same bushing IH used as a front motor mount. So easy to find.
RPT is very high quality. And if for some reason it goes bad they are rebuildable. I would highly recommend them. Just make sure you get the correct one for your application.
1972 SII. Taking all my money since 1998. Affordable accounting, payroll services and payroll management |
Thanks.
I have a few other other RPT parts and have been pleased with them, definitely high quality. Just wanted to get some feedback before spending $$. |
Thanks again for the help...was able to take the bolts off the u-joint today and the get the entire driveshaft out.
Lucky me, the yoke at the TC was cracked as well. Where can I get a yoke for the D300?? Is it the same as the D44 pinion yoke? Also, anyone have the part number for the output seal, may change it while I am at it too |
check out Novak-adapt.com,i'm sure you'll get a yoke and seal from them.jeff
| 345 , 727 , bar , bolts , box , case , clean , cracked , crossmember , d30 , driveshaft , find , front , mount , parts , removal , remove , replacement , rubber , scoutii , transfer case , transmission , transmission mount , turn , u-joint |
| Scout II SOA Jeep cv driveshaft? | 46binder | General IH Tech | 4 | 04-02-2012 05:09 PM |
| Front driveshaft question.. | slowboy | General IH Tech | 6 | 01-31-2012 01:43 AM |
| Front CV driveshaft? | Brandon A. | General IH Tech | 2 | 08-12-2010 09:15 AM |
| CV Style Front Driveshaft For Scout 80/800 | MikeInMobile,AL | BP IH Knowledge Wiki | 0 | 02-20-2009 08:28 PM |
| auto trans and front driveshaft | NOT76 | General IH Tech | 1 | 11-02-2003 11:43 PM |
