Old 05-01-2012, 07:08 PM
Duncan Duncan is offline
Default Lift gate Latch Pin
I tried to find it on search on the forums and struck out on google so maybe someone here has had a run in with one and has the part number to it. It is the pin that attaches to the body for the full rear hatch on a traveler. When I bought my blue beasty it was broken off and now it is annoying me and keeping the rear hatch out of alignment.
If anyone has bought one of these or even has one laying around let me know I need one.
Old 05-02-2012, 06:53 AM
Default Re: Lift gate Latch Pin
Ok, finially found one on-line. It is a Striker bolt. Scoutparts has them for $99.99, yep I will be heading down to the local homedepot to find an matching bolt and putting heat shrink on the threads. Also here is the IH part number if anyone needs one 342003R1.
Old 05-02-2012, 06:56 AM
travbo24's Avatar
travbo24 travbo24 is offline
Are you sure it's just a bolt? My Traveler has the same strikers for the lift gate that are used with the normal Scout II tailgate. That's why when you want to run a tailgate with the top off, you just move the strikers up to the second location. They are attached through the body with two big machine screws that bolt into a backing plate behind the tailgate housing.
Shouldn't be too tough to find...I think I may have a couple of them.
'78 Scout Traveler - Midas
Old 05-02-2012, 08:41 AM
Well it is not a bolt but we are talking about the same thing. It is for my 77 traveler. I have a feeling i can reproduce the same thing out of the bolt bin in home depot. Thread lock a flat nut on the back to hold it to the plate, and grind down the head abit. Cost me a few bucks and 30 min work. The Pin is what snapped off so i still have factory Plate available for mounting.
alignment , body , broke , cost , find , google , grind , lift , lift gate , lock , number , part , parts , rear , scout , scout ii , screws , search , top , traveler , work
Traveler lift gate adjustment Buddy General IH Tech 16 05-09-2013 07:29 AM
C-series door latch problem Clinton King General IH Tech 5 07-02-2009 04:38 AM
Carpet Kit, insulation, Lift gate struts Dave J General IH Tech 20 08-27-2008 07:25 AM
CHEAP Lift Gate T Handle N2IHC General IH Tech 18 02-04-2003 06:08 PM
68-T-All Concerns(body bushings,fuel sender,tail gate lift motor,etc) *LONG* Glenn N. Lewis General IH Tech 1 10-21-2001 11:24 AM
