Old 05-01-2012, 07:33 AM
viggidy viggidy is offline
Default Scout 800 B gauges
Replacing oil and temp gauges on my scout 800 B. The previous owner has a set of sunpro gauges. I would like to replace or go back to factory stock gauges. I have the gauges and ready to go. Problem is there is a sensor cable on the oil and temp has a different back on the sunpro compared to the stock. Again this may be a easy fix just dont want to start ripping things out and not be sure on how to go back to factory gauges.
Old 05-02-2012, 06:04 AM
Albuq. Henry's Avatar
Albuq. Henry Albuq. Henry is offline
Send a message via AIM to Albuq. Henry
Default Re: Scout 800 B gauges
Sounds like the PO went with mechanical guages, the origional were electric. First I would make sure all the wiring is good, Does your fuel gauge work? If so that is good because you have good power and the cvr is good. See if you can tell which are the wires going to the sending units and if the sending units are there.
Originally Posted by 800bman View Post
Jeff,
I wish I could enter your brain somehow and relive the memory of buying an 800b brand new! I'm drooling with jealousy!
Old 05-02-2012, 06:08 AM
Mark B 70SR2's Avatar
Mark B 70SR2 Mark B 70SR2 is offline
You're likely going to have to get some factory sending units. You might can find them at the local auto parts store.
......__________
.... |__________|
.[]<|0|_______|0|>[]
....|.... |.v....|.....|
....|___|.......|___|
Old 05-02-2012, 06:56 AM
Thanks for the info. The only one that worked was the amp. Again thanks for the info
800 , cable , cvr , electric , find , fuel , fuel gauge , gauges , mechanical , oil , parts , power , problem , scout , scout 80 , scout 800 , scout 800 b , start , wiring , work
70 Scout 800 Crusher Save Scoutman88 Binder Builds 23 02-13-2012 10:04 AM
In need of any line ticket for a Scout 800 showing D44 ordered urbex General IH Tech 8 09-18-2010 07:26 PM
