Go Back   Binder Planet Forums > IH Clubs > Member-Club Forums > Tennessee Valley Binders
Old 04-29-2012, 04:52 PM
Anthony Weigant's Avatar
Anthony Weigant Anthony Weigant is offline
Default TVB Trading Post
Got something you don't want? Want something you ain't got?
Post it here!
Just like all threads like these, be sure to describe your item or vehicle as acurately as you can, with price, location, and pictures if possible.
Also please leave the best way to contact you; pm, email, or phone.
Thanks for playing along, now sell your junk!
Tony
Hey! Look here! This thing's a piece a junk!
Old 04-29-2012, 07:26 PM
lev1a's Avatar
lev1a lev1a is offline
Default Re: TVB Trading Post
J.J. or J.G. use your super mod powers to sticky this thread. Please and thank you.
http://oldironoffroad.com/
Old 04-29-2012, 08:06 PM
Caveblazin's Avatar
Caveblazin Caveblazin is offline
I'll start this off then..
Wiring harness for sale!!
I have for sale a front wiring harness, engine wiring harness and universal 12 circuit wiring harness. $100 plus shipping or if local you can come get it.. Always consider trades
Front wiring harness is setup for-
High beam headlights, low beam headlights, front markers, right front turn, left front turn, and horn. The entire harness has been cut to length, taped, loomed, and terminated! It comes with all necessary terminals, instructions, and a easy to follow color wiring diagram. Has weatherpack connector at the firewall end.
Engine wiring harness is setup for-
It includes circuits for: Charging system, Starter, Elec. choke, H.E.I. or Standard Ignition system, Oil sender, & Temp. sender. And comes complete with terminals, extra wire, wiring diagram and detailed instructions
Universal 12 circuit wiring harness-
This 12 circuit universal wiring harness is perfect for any 12 volt application. Jeep, Bronco, Hot Rod, Scout II or whatever your project may be this kit provides all the basic circuits along with a modern ATC style fuse panel to wire your dash and interior quickly and effectively!
Included is pre-wired circuits for:
Instruments, Heater, Wipers, Turn Signals, Brake Lights, Headlight sw., Hazard lights, Electric Fuel Pump/Cooling Fan, and FIVE spares for additional accessories.
** Each wire is color coded and labeled every few inches for easy I.D. **
Also included is:
(1) ATC/ATO modern blade style fuse block with terminals and fuses installed, 92+ ft. of GPT 16ga. wire terminated and installed into the fuse block, 16 ft. of GPT 12ga. wire terminated and installed into the fuse block, Integrated 40 Amp. Fuel Pump/ Cooling Fan Relay, Integrated Signal Flasher, Hazard Flasher, 12 connectors, Fusible Link for Fuse Block Protection, and detailed instructions with a Wiring Diagram!
Old 04-30-2012, 10:51 AM
J.J.'s Avatar
J.J. J.J. is offline
DONE!
Trade away.....
JJ
Old 05-21-2012, 06:19 PM
ScoutItOut82's Avatar
ScoutItOut82 ScoutItOut82 is offline
Hi everyone,
Tennessee new guy here, not new to Binders just moved to TN from Colorado. I am in desperate need of a hard top for a Scout II and also a tailgate for the same, also a backseat and all four seatbelts. Kind of a tall order I suppose, I don't have much to trade but I can try to muster up some cash for the kind soul(s) that can help me out! I do have some beat up corbeau style front bucket seats that I would like to trade for a set of factory style low back buckets.
Thanks guys!
Scott
Be unique. Use your hands. Go out and create.
'76 Scout II "Daily driver/learning experience" R.I.P. (Damn Thieves)
'77 SII "Work in Progress"
Old 05-22-2012, 04:45 AM
crazyeight's Avatar
crazyeight crazyeight is offline
Welcome Scott!! Sent you a PM.
Mike
Mike Richardson
1977 Scout SSII - Street and Show Ride
1972 Scout II - Trail Ride
1971 Scout 800B - Soon to be Daily ride
Charter Member Tennessee Valley Binders
Old 05-23-2012, 08:06 AM
J.J.'s Avatar
Originally Posted by ScoutItOut82 View Post
Hi everyone,
Thanks guys!
Scott
Welcome Scott!
JJ in TN
Old 06-20-2012, 08:06 PM
Monkeyplasm Monkeyplasm is offline
Default 2 Dana 20 Transfer Cases
Gone.
Old 06-20-2012, 08:10 PM
Default 1980 Scout II axles
Just pulled from my 1980 Traveler, making room for 3/4 ton full width axles.
Very good condition, no work needed. Bolt in and drive. Warn premium hubs. 3.31 ratio.
$500. No shipping. Nashville, TN.
Old 06-20-2012, 08:16 PM
Default 4" Scout II lift springs
Gone.
100 , brake , cooling , dash , engine , firewall , front , harness , headlights , heater , hot , ignition , oil , panel , pictures , price , project , sale , scout , scout ii , start , starter , tire , universal , wipers
Post Dixie Regionals check in and picture thread SCscoutguy Southeast Binders Association 30 05-31-2006 12:18 PM
New wheels. Post your pix for ideas. rleeds General IH Tech 31 05-11-2006 02:32 PM
how to post pics?? rustfreeTX General IH Tech 6 04-18-2004 01:34 PM
Have post #'s dropped?? Chrispucci General IH Tech 7 11-26-2001 09:54 PM
