Yes. The T19 transmissions were all the same between diesel and gasoline Scout IIs. There is a T19 wide ratio with a first gear ratio 6.32. I'd avoid putting that into a diesel Scout it has some big jumps between some of the gears.
R. Dale Durham Colorado Springs, CO 1980 Terra 392IC V8 T19 Wide Ratio Dana 300 T-Case Four wheel disc brakes SOA w/2" body lift Warn 8274 winch On board air and welder Optional rust, custom dents & multi-color body parts Last edited by RD Durham; 04-27-2012 at 09:01 AM. |
Thanks. Found one an hour away.
| 4.0 , broke , diesel , gear , gears , question , scout , scout ii , swap , wide |
| 1970 Travelette 4x4 axel swap question | Truckee530 | Triple Diamond Trucks | 7 | 07-30-2010 07:13 PM |
| Transmission swap question. | rangerslim | Southeast Binders Association | 17 | 07-20-2010 07:37 AM |
| 800 tub swap and windshield question | ihscoutmatt | General IH Tech | 2 | 03-09-2010 12:33 PM |
| T19 question | Harl | General IH Tech | 5 | 05-05-2007 04:44 PM |
| Engine Swap question | badasp | General IH Tech | 8 | 11-27-2005 11:37 AM |
