do we need this? or are we okay to run on the low sulfur stuff? driving a 1978 with 1976 engine. non turbo, as i haven't put one on it yet, hahaha
my name...Landon my ride...1978 Scout II rebuilt SD33 n/a, T19, Dana 20, 3.73's rear limited slip, 31 inch Toyo mts, lift is about 3 inch front and 5.5 rear done with add a leafs and shackles. my favorite hobby...
if you use the search there has been a number of discussions on this, the short of it is most suggest using a high quality additive. I'm not sure off hand what brands have been discussed.
Shane 1980 Scout II Diesel |
i did use the search and only 4 threads came up, read them all and found nothing.
hence the new thread... my father who has been driving a log truck his whole life said if its necessary to run one i should probably use "howes" or "power service". how do ya feel about that? he told me that it pays for itself in fuel mileage increase and power difference. since he told me that i was planning on running one anyway but wanted to know the opinion of other sd33ers. so i figured id ask. thanks for the reply watermunky.
I use howes
Eric |
I'm using canola oil as a lubricant additive in all my diesels.Way cheaper than the other stuff.
couple of reads:
http://www.binderplanet.com/forums/s...ighlight=howes http://www.binderplanet.com/forums/s...ighlight=howes
so i decided to just start using power service in the silver bottle and it helps with start up and start up smoke. when its warm all i do is hit the plugs for 10 seconds, then just barely hit the starter and it fires right up! havent started with out using the plugs just cuz i dont see a reason to try it. they are there for a reason so i use them.
thanks for the help guys
Used motor oil if kept clean and dry is used by alot of people I know to help make fuel more slick. Opti-Lube is one of the best choices out there if you are judging on lubricity.
Bio-Joe Renwick Winnsboro, SC "If it Ain't Broke, You haven't Driven it Hard Enuff Yet!"
Lots of people I've talked to swear by the Stanadyne stuff. It's supposed to be especially good on rotor pumps (Stanadyne, Roos Master, etc.) which are also fitted on the 6.9/7.3 engines.
My self, as being really cheap, I use some canola oil when not running my own bio fuels. -Paul
Paul Wargenstahm Computer & Electronics Engineer 1967 IH 1000B with GM 6.2D, TH700R4, running WVO and BioDiesel. 1964 IH C1200 4x4. The new one... ![]() Build-up pics at: Paul's IH Pages (updated Sept 7, 2012) |
| 1978 , additive , binderplanet , clean , diesel , difference , engine , fuel , low , number , oil , power , question , search , short , show , smoke , start , starter , stupid , truck , turbo , wanted |
| Diesel Is Not Gas! | MikeInMobile,AL | BP IH Knowledge Wiki | 0 | 02-20-2009 09:22 PM |
| Confessions of a long time Dieseler | John Donnelly | Diesel Tech | 4 | 04-02-2007 10:47 AM |
| The IH Diesel FAQ (with SD33 info) | John Donnelly | Diesel Tech | 3 | 01-28-2007 12:43 PM |
| Diesel Tech Seminar at Nats 2006 | Eldon McFarling | Diesel Tech | 17 | 09-10-2006 08:54 PM |
