Im hoping that it was just the rod going un-noticed and then popped out What do you think? |
I think Harvester motors don't like to be over reved, I can't imagen you did that with a braker bar
Look to how the lifters are installed and be sure and break the engine in carefully.Replace the bent push rods, once bent they will tend to rebend even if you get them straight, cheap at Napa or Car quest.
Robert AKA Jetfxr RIP Ricky you are missed. Did you check the green wire? 1973 Travelette ton axles on 35s 1977 SSII Just a little modified ;o) 1980 Scout with 375hp LS1
Charter Member, F.O.P. (Friends of Poseidon) |
Is it possible the long bolt length interfered with the push rod as it went through its travel and forced it to bend, then pop out of its seats?
'74 Scout II 345 T-18 D-20 44's Fr/RR '79 Scout II 345 700R/NP241 44's Fr/RR |
my parts manual states 8,-1" bolt's,4,-1-1/4" bolts,4,-1-1/2" bolts.for the intake manifold.you want them at least 1/4" away from the push rods.i believe the 2 center bolts on each side are the 1-1/2" bolts,jeff( 3 different sizes) ALL bolts have washers also.the 345 i just tore down didn't have washer's on the 2 lifting hooks.jeff
Line up the timing marks before unbolting the rocker shafts. Replace all pushrods and make sure timing marks are aligned before installing rocker shafts. See FSM for more details.
---Honestly? A rebuilder should have a warranty so I don't know why you're troubling yourself with it unless it was a friend who did it off the clock, which in most states is illegal from an insurance aspect. Having manuals open to walk one through the job is the first lesson in automotive. Just for the simple reason of what was said here...
---The reason being is that this will be the lowest position on all camshaft lobes, thus it will be the least amount of pressure on the valve train. Manuals would have stated this. ---If it hasn't been suggested yet, it would be best to check all* pushrods for straightness and replace all that are bent even the slightest bit. ---Lube all parts with something like TB Zinc Plus, if not a standard assembly lube. Some people even use Vaseline, but not me. I use what I want my oil to have in it... and I use 30W oil. If it's new, rebuilt, whatever, I hope you didn't listen to xxW50, cause 50W has never been called for in our engines. Never.
| 345 , bar , bearings , bolts , broke , cam , case , crank , distributor , ebay , engine , find , intake , international , kit , lift , problem , remove , replacement , rust , scout , shop , v345 , valve , work |
| Ouch! Broke an axle... will it happen again? | JasoninAustin | Hill Country Binders - Central TX | 6 | 10-20-2009 07:13 AM |
| Locking Hub question, I think i broke mine:) | kcooper936 | General IH Tech | 1 | 07-01-2007 12:23 AM |
| Front hub broke, Anyone seen this before? | Bill Rodgers | General IH Tech | 8 | 08-18-2005 06:18 AM |
| one heck of an adventure! (long) | IH64Scout | General IH Tech | 0 | 05-03-2004 03:38 PM |
| dun just broke down | scoutkid | General IH Tech | 19 | 05-28-2002 06:58 PM |
