Old 04-20-2012, 01:32 PM
rbelflower rbelflower is offline
Default Door locks are unlocked after closing
Hello all,
I have kind of a unique issue.
On My 76 Scout II, when I lock my passengers door while it is open, then shut it, the door lock is down but you can reopen the door.
If I lock the door after it is closed, it remains locked.
This is not the "partialy open" door issue. The door is fully closed everytime.
If I lock it, close it, then push just a little bit more on the lock, it remains locked as well.
Oh, and if anyone knows where the tread is for the Scout 800 door lock modification is, would you please post it.
I cant seam to find it.
Any thoughts?
Thanks Rob
Rob
76 Scout II
345/700R4 Auto/Dana20
Dana 44 F/R
Hardtop/Soft top
67 Scout 800
152 stick to be modified
Hardtop/Soft top (soon I hope)
Old 04-20-2012, 05:13 PM
Default Re: Door locks are unlocked after closing
Not sure on IH but some old Mopars and new VW are like that. Keeps you from lovcking the keys in. You need the key to lock the doors. For reference my 69 Roadrunner does that
Old 04-20-2012, 05:34 PM
Thomas's Avatar
Thomas Thomas is offline
---As ruderunner stated, yours is only unique due to the later model Scout IIs allowing the door to close and stay locked. Most recent posting I have seen on the topic was on 12-08-2011 @ 05:14 PM where TheScoutMaster asked,
"Why do idiots insist on pushing the door lock down when getting out???"
---II forget who originally mentioned it, one of the long-timer members, but in that thread I give a brief explanation of how to alter the latch so you can make yours work like the later models do. I've done it on StoneThrower; It's very easy. Much simpler than reaming the door lock mounting holes & cutting the lock rods, so the doors will accept the later model Door Lock Cylinders.
T.R.E.Jr.(Fortiter Et Recte)
53 Farmall H=Heinz
49 IH fridge=?
Who loves hearing,
Old 04-20-2012, 06:00 PM
joker51's Avatar
joker51 joker51 is offline
What if you push the outside handle button in while shutting the door? I remember having a car that I had to do that with. Dont remember what car it was.
Joker51
Old 04-20-2012, 07:22 PM
Thank you to all,..
This is a new issue.
I used to able to close the door when it was locked without issue.
I will try holding in the button.
The lock pin stays down,.. but it can go down about another 1/16" after the door has been closed. then it will not open up.
FYI,.. The drivers door does not have this issue.
Thomas,
I read that post as well.. found it a bit interesting.
That is what also sparked the thought of modifying my Scout 800's locks.
I have an extra set of locks (for my 800).. maybe its time to start experimenting.
Rob
76 Scout II
Dana 44 F/R
Hardtop/Soft top
67 Scout 800
Old 04-20-2012, 07:33 PM
joker51's Avatar
Ok if its just one door more than likely its just the lock mechanism needs to be rebuilt. Sound likes its a little worn and popping up a hair when the door shuts.
Joker51
Old 04-20-2012, 07:47 PM
Joker,
Thank you. That makes sense.
Anyone know where to get a rebuild kit?
Or anyone have a good working unit they don't want?
I have checked a couple of the LL vendors and I found the springs but not too much more.
Rob
76 Scout II
Dana 44 F/R
Hardtop/Soft top
67 Scout 800
Old 04-20-2012, 08:00 PM
joker51's Avatar
Hope its the fix. and I will look around see what I can find also for you. Might have to hit the salvage yards and just replace it and use your cylinder or have 1 rekeyed.
Joker51
100 , 800 , binderplanet , body , car , cutting , door , doors , find , lock , master , rebuild , rebuild kit , scout , scout 80 , scout 800 , scout ii , show , size , sound , springs , start , vendors , work
