#31
#32
Like Stu said, they're LH threads, as in righty loosy/lefty tighty. You're turning them the wrong way. That much white smoke from the exhaust would have me suspecting a blown head gasket. Got any chocolate milk showing in the crankcase?
#33
Drained the oil and everything looked ok. Cleared up a little bit after running it today. Any ideas how to get these nuts off???? |
#34
Did you say you had a flanged D44 rear or the hub/axle D44?
Charter Member, F.O.P. (Friends of Poseidon) |
#35
Finally managed to get the lugs off and replaced all the studs on the drivers side. Got the wheels mounted and now I'm rubbing really bad.....
If its not 1 thing, its another!!! Any cheap fix for now? Not really interested in doing a spring over right now.... |
#36
#37
Looks like the springs are sagging a little. I would try putting in an extra leaf or even a lift kit.
Im thinking an extra leaf or spring helper (think thats what they are called) would be the easiest and cheapest route. Found a suspension lift kit $865 at anythingscout. That might be a way to go also. Joker51
Joker51 1979 Scout Traveler with SOA, 33" tires, 345, 727 tranny |
| 196 , 800 , air , battery , brakes , cap , carb , clean , cylinder , filter , fuel , fuel filter , gas , holley , inspection , master , project , rebuild , scout , scout 80 , scout 800 , seat , top , valve , wheels |
| Holley 1904 woes | Dan&Becky'sScout80 | General IH Tech | 8 | 04-17-2012 10:59 AM |
| Holley 1904 dumping gas on passenger side | thetodd | General IH Tech | 18 | 11-28-2008 08:47 AM |
| holley carb kit | biggomba | General IH Tech | 0 | 01-20-2008 10:51 AM |
| S120 IH Holley carb settings | Britcheflee | General IH Tech | 0 | 08-08-2007 12:55 PM |
| Carb Rebuild Part Number for Holley 1904 4 cyl | Jayrodoh | General IH Tech | 0 | 03-10-2004 06:55 AM |
