The wipers have be converted and are no longer vacuum operated. |
take the fitting out of the dizzy,an put some sealant or teflon tape on the threads,re-install an see if it doesn't help.jeff
This is a shot in the dark, but when I was getting mine going, it would never run for more than 15 seconds. I discovered that the engine ground strap from the block to the firewall was disconnected. Once I reattached that, it was off to the races...well, off to the next issue anyway.
![]() From your pics, it looks like yours is in place, but I think there is another engine ground, I just can't remember where. Good luck!! Nice looking rig, BTW!!
Tim 1967 Scout 800 (196) |
It seemed to have fixed the choke problem, and not it will run without the choke, however, it is spitting and backfiring through the carb now. |
That should have said that it will now run without the choke on.
With the backfiring throught the carb, would that be a timing issue? |
Be careful though, especially if the wires are old, as it will bite you. I usually make adjustments with the engine off until I get it close. Did you cap off the line to the distributor or did you just seal the threads? |
-Gary
El Guapo: Jefe, would you say I have a plethora of Scouts (and two Travelalls and a Pickup)? Jefe: Yes, El Guapo. You have a plethora. |
I have new points, condensor, rotor, cap, wires, and plugs. I sealed the threads and sealed where the hard wire goes onto the nut where it screws onto the dist.. I don't have a timing light.... |
| 196 , 800 , air , battery , brakes , cap , carb , clean , cylinder , filter , fuel , fuel filter , gas , holley , inspection , master , project , rebuild , scout , scout 80 , scout 800 , seat , top , valve , wheels |
| Holley 1904 woes | Dan&Becky'sScout80 | General IH Tech | 8 | 04-17-2012 10:59 AM |
| Holley 1904 dumping gas on passenger side | thetodd | General IH Tech | 18 | 11-28-2008 08:47 AM |
| holley carb kit | biggomba | General IH Tech | 0 | 01-20-2008 10:51 AM |
| S120 IH Holley carb settings | Britcheflee | General IH Tech | 0 | 08-08-2007 12:55 PM |
| Carb Rebuild Part Number for Holley 1904 4 cyl | Jayrodoh | General IH Tech | 0 | 03-10-2004 06:55 AM |
