It was last licensed in 97 I have replaced the battery, plugs, wires, cap, rotor, points, and condenser. I had Outback rebuild my carb. I can only get it to run when it is fully choked and floored. It will run for about 15 seconds and then die. As soon as I put in the choke, it dies. I have the fuel/air screw 1.5 turns out. The fuel filter is working fine. I'm running dual inline fuel filters and they are still clean. I'm located in Spokane, just off Maple on lower South Hill. I would be willing to pay someone who can help me get this thing running. I also have replaced the master cylinder and bled the brakes. I have bought some nice wheels and 31 10.5 15's that I am dying to put on, but they are at my work and I cant get the scout there!!!!! I had it running for a while, and then gas started coming out of the top of the bowl from the overflow valve. I noticed upon inspection that the brass washer from these pics was missing. I put in a silicone washer that fits but it might be a little too big. I took the bowl cover off, held up the float and when turned over it had a fuel coming out of the hole above the needle, but no longer was coming out where the fuel inlet seat screw attaches. Here is a pic of the washer that I am missing..... Any ideas what I should look into next? Last edited by SERENate; 04-29-2012 at 04:50 PM. Reason: changed title |
Here are some pics of the scout.....
Tires and Wheels...
It has a Holley 1904 on it.
Check out this page toward the bottom, it describes your scenario pretty closely- http://www.ihonlynorth.com/forums/ca...b-stuff-3.html
Bet you have a massive vaccum leak. Is the carb secure on the manifold? Any open ports in the carb that would allow air in? Vaccum advance line to distributor intact?
One other place to check on these rigs is the line for the windshield wipers. The leak could actually be originating behind the dashboard where a line has come loose from the wiper motor, or had a small critter such as a mouse chew a hole thru it.
1966 Scout 800 - purchased 1995 1972 Scout II - purchased 2005 _ _ _ _ _ _ _ - purchase in 2015? |
So the trouble is all related to the carb. Full choke on and floor pedal to run could imply the carb is clogged up, fuel not flowing out of the jets. I would do a complete dissasembly to verify all the passages and make it function properly. |
pics of my setup....
| 196 , 800 , air , battery , brakes , cap , carb , clean , cylinder , filter , fuel , fuel filter , gas , holley , inspection , master , project , rebuild , scout , scout 80 , scout 800 , seat , top , valve , wheels |
| Holley 1904 woes | Dan&Becky'sScout80 | General IH Tech | 8 | 04-17-2012 10:59 AM |
| Holley 1904 dumping gas on passenger side | thetodd | General IH Tech | 18 | 11-28-2008 08:47 AM |
| holley carb kit | biggomba | General IH Tech | 0 | 01-20-2008 10:51 AM |
| S120 IH Holley carb settings | Britcheflee | General IH Tech | 0 | 08-08-2007 12:55 PM |
| Carb Rebuild Part Number for Holley 1904 4 cyl | Jayrodoh | General IH Tech | 0 | 03-10-2004 06:55 AM |
