Old 04-17-2012, 04:18 PM
Lgn1738's Avatar
Lgn1738 Lgn1738 is offline
Default
Ford bolt in master cylinder swap
Built front crossmember and new box mount
Old 04-17-2012, 05:49 PM
Lgn1738's Avatar
Default
Attachment 67844
Cut some long travel front shock mounts from some 2x4 I had left from the front crossmember. Just tacked till I cycle the suspension.
Attachment 67845
Out side for the first time pulled a few leaves out too.
Old 04-17-2012, 06:16 PM
Lgn1738's Avatar
Default
Old 04-17-2012, 06:23 PM
Lgn1738's Avatar
Default
Shot of mount. I put a gusset in the center to help support the sector shaft.
Old 04-19-2012, 07:10 AM
Lgn1738's Avatar
Default
So now I had the brakes done and steering sorted out I cleaned up the carb again. Got the motor running and it picked up a bad knock. I was pretty discussed cause I had started collecting fuel injection parts. Also around this time I saw a build on here with a diesel swap. So the next week I went and got an 82 Mercedes 300sd.
The swap seemed to be a popular diesel option with the Toyota crowd. It was alot cheaper than any 4bt or sd33 I could find and these motors turn pretty high rpm which with the 5.13 gears I had just done in my axles was a plus.
Old 04-20-2012, 10:09 AM
Lgn1738's Avatar
Default
Flat towed it the 8 blocks from my house to work and tore the IH mill and trans out
Old 04-20-2012, 10:13 AM
Lgn1738's Avatar
Default
Put it back in the garage and collected more parts. Including a th350 Dana t case adapter and OM617 to th350 kit.
Old 04-21-2012, 09:46 AM
Lgn1738's Avatar
Default
Swinging the turbo diesel in for the first of many times
Old 04-21-2012, 09:49 AM
Lgn1738's Avatar
Default
Did some fire wall trimming to bring it back and down in the hole. Filter housing was a problem.
Old 04-21-2012, 09:53 AM
Lgn1738's Avatar
Default
Decided the existing wiring was not worth trying to salvage so removed it and the dash trimmed a little more fire wall
adapter , box , build , bus , cage , case , deal , diesel , drive shaft , driveshaft , kit , orange , part , pickup , project , rear , reproduction , scout , scout 80 , short , show , spicer 18 , swap , terra , truck
Online store Updated with More Products Jeff Ismail IH Parts America 1 11-25-2009 09:39 AM
Scout 80 Build Tres03 Hill Country Binders - Central TX 11 06-11-2009 11:46 AM
80/800 Serial Numbers Will Marsh BP IH Knowledge Wiki 0 02-01-2009 09:42 PM
1985 CJ Leaf Springs on Scout 80? Finder-Binder General IH Tech 1 07-11-2003 11:06 AM
