Old 04-11-2012, 07:17 PM
hairygrapes hairygrapes is offline
Default 73 cab on 75 frame drop right on?
Think it should go right on and everything connect am I wrong on this?? Found a mint 73 cab for my 75 200 4x4. Thoughts?
Old 04-11-2012, 08:12 PM
Default Re: 73 cab on 75 frame drop right on?
From all the measurement I did when I wanted to do this on a travelette is no.The front cab mounts are different,the 74/75 have 2 bolts per side annd the 73 only has one.Do alot of measuring before you buy it,might be easy to do,I was afraid to do it as the cab was a couple hundred miles away
Old 04-12-2012, 08:57 AM
They are different. You will have to weld up some mods.
Not impossible.
Old 04-12-2012, 07:03 PM
Is the wiring atleast the same or am i better to just cut and weld the steel into the 75 cab?
Old 04-12-2012, 07:39 PM
J.J.'s Avatar
J.J. J.J. is offline
Wiring is totally different. Difference is key on dash (73) vs column like your 75.
Old 04-12-2012, 08:17 PM
Yes, was aware of that, but what about the firewall connectors and such for the main harnesses, heater controls etc.?
200 , 4x4 , bolts , cab mounts , column , dash , difference , firewall , frame , front , heater , key , mounts , travelette , wanted , wiring
CREWzer CAB TRANSPLANT sparkydog The Skunkwerks 567 03-25-2013 09:28 AM
Frame Repairs - steering box Tom Mandera The Skunkwerks 21 05-17-2011 11:18 AM
frame thickness 1110/1300?? Darren Y. General IH Tech 4 09-27-2006 02:20 AM
Prior accident or '72 frame config different? Nickrt General IH Tech 1 07-18-2005 06:02 PM
