Old 04-04-2012, 02:06 PM
jrmtx jrmtx is offline
Default 77 terra woes
I am having a great deal of difficulty getting my 77 terra to run and stay running. I have replaced the fuel pump, installed a pertronix ignition module to replace the gold box, added pertronix wires and coil, and had the 2210 carb reworked by Gauranteed Carburetor (most recent mod). When I first installed the carb, the engine fired and ran sort of ok. I know the distributor need to be turned to get it to run better but not I can't hardly get the thing to start let alone run. It acts like it is not getting fuel but I disconnect the line, crank the engine, and fuel sqirts out. Long story short, anyone got any suggestions?
Old 04-04-2012, 02:10 PM
Carl Wiese's Avatar
Carl Wiese Carl Wiese is offline
Default Re: 77 terra woes
Have you checked the fuel pressure and do you have a fuel filter. I had a similar problem with a pickup I was working on and had low fuel pressure and tons of sediment in the tank. I'd go to your favorite autoparts store and start by picking up one of the glass in line fuel filters so you can see if there is sediment in your fuel. You should be able to get and in line fuel pressure gauge as well.
IHSTO Club President, please feel free to contact me with questions and comments.
CoD - Prodigal Son
Old 04-04-2012, 03:49 PM
scoutboy74's Avatar
You replaced all the plug wires. Did you verify that they are routed in accordance with the cylinder firing order? It is very easy to miss-route one or more wires, and you can't just assume that Johnny PO had the previous set routed correctly, in case you replaced them one at a time.
Trever Whetzel
Fat White Boys
Binder Recovery
& Rehabilitation
SHOP NORTH
Old 04-05-2012, 06:44 AM
supermerle supermerle is offline
Just because the carb as been rebuilt doesn't mean that the carb is GOOD? Sounds like a carb problem to me and from my experience.
Old 04-05-2012, 07:05 AM
Fred Demmon's Avatar
i would lean torwards a timing/ignition issues.
But
did you drain the old fuel out before installing the new carb?
Where are you in Texas? maybe one (or more)of the local Binder Brothers could lend a hand
President
Gulf Coast Binders
75 SII 304 4 speed
65 80 152 3 speed
77 SII 345 Automatic
75 SII NO engine or trans
74 SII 196 4 speed
76 SII 196 4 speed
80 SII turbo diesel 4 speed
Old 04-05-2012, 07:08 AM
I see you are in the Del Rio area
Not sure if there are any active IH guys in that area
President
Gulf Coast Binders
75 SII 304 4 speed
65 80 152 3 speed
74 SII 196 4 speed
76 SII 196 4 speed
Old 04-05-2012, 01:20 PM
Thanks to all for your assistance/suggestions. Let me try to answer each question.
1. I have checked and rechecked the plug wires and am fairly certain they are correct...emphasis on fairly. This is assuming that the #8 tower on the cap is slightly left of center when beiwing from the font of the vehicle.
2. I have not checked the fuel pressure but have a test gauge on the way to test that as well as the vacuum. With that said, I am getting some confusing informatin about where to connect the dizzy vacuum advance hose. Currently, it is connected dirtectly below the fuel inlet on the carb base.
3. I did install a new fuel filter but I did not drain out the fuel tank since I had to replace the hose that runs from the filler neck to the tank after all of the fuel drained out from a rotted hose.
4. As for location, I am close to Del Rio. When I ask a "mechanic" questions regarding the Scout, I get the 'deet in the headlights' reaction.
5. I agree that just because a carb is "rebuilt" does not mean that it problem-free. After reading some other forums, it seems that the Holley 2210 is problematic at best.
Old 04-05-2012, 05:29 PM
binderbart's Avatar
binderbart binderbart is offline
did this scout sit for a while or was it a running scout before all this started? from what I read it sounds like you changed a lot of things right away which could have created some problems along the way. If it was mine I would set the timing mark at TDC and see where the rotor was pointing in the distributor. then run your wires off of that. once that is done you would be close enough for the timing for it to fire up and you could address any fuel issues at this point. I always pull the line off the carb and stick it in a 20 ounce pop bottle and crank it over , if you fill half the bottle in 3 to 5 seconds its a good guess the fuel pump is putting out enough to supply the carb. I would start with this as you installed the petronix. could just be a simple fine tuning issue you got going on.
Why farm half when you can FARMALL!
73 scout II- "Agnus"
76 terra
77 trail scout (custom body)
79 GMC 3/4 ton (Dad's truck) "The General"
02 H.D. Sportster 883R
Old 04-09-2012, 01:44 PM
Got my vacuum/fuel pressure test gauge in. Connected to fuel line and am getting good fuel pressure. However, when I checked for vacuum at the 3 nipples available on the carb base plate, I get no vacuum at all on any of them. Any suggestions?
Old 04-09-2012, 03:35 PM
joe frank's Avatar
joe frank joe frank is offline
Check "freeze" plugs under the intake. Might have a hole in one.
1966 Travellette 304 granny 4 speed 2wd powr lock
Hunter Oldham
Son of J.D Oldham
box , carb , carburetor , case , coil , crank , cylinder , deal , distributor , engine , firing , fuel , fuel pump , gold box , ignition , ignition module , pertronix , pickup , plug , pump , scout , short , start , terra , timing
Terra or 800B? BioTex General IH Tech 12 02-25-2010 03:16 PM
Terra Top Fit Scout Ii Square Windows On A 77? Anyone With A Terra Post Pics! Jeff Brown General IH Tech 14 03-30-2004 03:36 PM
