Old 04-01-2012, 08:35 PM
NONYAMT NONYAMT is offline
Default 1962 scout 80 drum removal ?
Do I need a puller to remove a rear drum?Trying to replace wheel cylinders and shoes but I cant get the drum to budge after pulling the 3 screws in the face.Thanx
Old 04-02-2012, 07:34 PM
Greg R's Avatar
Greg R Greg R is offline
Default Re: 1962 scout 80 drum removal ?
If there's a big nut on the end of the axle shaft, more than likely you will need a puller.
69 800
266 V8/4spd & D18TC/OD
4.27 D30/ D44
'56 S110 240 I6/4spd
'71 1210 345 V8/4spd 2WD
'67 Travelall BG246/4spd 2WD
Old 04-02-2012, 11:00 PM
Dave Nuenke's Avatar
Dave Nuenke Dave Nuenke is offline
Send a message via AIM to Dave Nuenke Send a message via Yahoo to Dave Nuenke
To remove the drum, you need to remove the entire hub. You must pop off the dust cap, remove the nut, and use a tool called a "hub puller" to remove the hub from the tapered axle shaft. There have been several threads where this process has been described in great detail.
Dave
Illuminati Hydrology Division
Old 04-06-2012, 03:56 PM
Sprayed the studs with deep creep,tapped the sides with a sledge and it came right off,the center hub and the drum are two seperate pieces.Thanx
Old 04-06-2012, 06:34 PM
you got LUCKY! they've been off before.jeff
196 , axle , cap , drum , hub , pulling , rear , removal , remove , scout , scout 80 , screws , studs , tire , wheel
Project - Get my dang Scout 80 back on the road! Mumpy General IH Tech 19 11-03-2010 11:08 AM
1962 Scout 80 Specs Brad Carpenter General IH Tech 2 02-23-2005 12:55 PM
1962 scout 80 good buy? fun to drive? rickauf General IH Tech 15 02-06-2004 04:46 PM
