I am thinking about doing a rebuild on a T-19w. I have never been into a transmission other than removing the cover plate. it may be fun to have a GCB work day "project" Anyone in the club have any experience doing this? I know there is a good amount of info on the net on DIY rebuilds. If I buy the parts & provide the space anyone interested in a work day?
77 Scout II = DEUCE, the ongoing project |
I'd definitely be in so long as its after the month of April!
1970 Scout 800A 304/T90/D20. Thats about all I know about it since I just bought it! |
it would be very handy to have a service manual,thats about all that you need.jeff
When I did the 3 speed (T90) in my scout 80 the most difficult part by far was finding the correct parts. I had an oddball with a different size needle bearing that couldn't be found by any of the vendors. I have a service manual and used Novak and a couple other write ups -big help. http://www.novak-adapt.com/catalog/t18_t19_parts.htm It looks like the T19 rebuild for IH is available at Novak - It would give you an idea anyhow of what your into. Ihon might have the kit too. Might be worth your while to research though to see if there are variants and which parts are common to wear etc. I had my tranny apart on the bench a couple weeks making phone calls and measuring parts.
a good work bench, press, bearing seperator is about all you need. i will be doing a T-18 shortly. as well as building a super 18. case. so i'm in if schedual lines up
AKA PYRO3256 Wanted 30's-50's IHC COE Truck 1979 scout II 1947 kb-1 |
I have been looking at Novak's page. I do not have a press, or Bearing separator. I can make a large bench in the garage. I also Have a T-19N that I am not going to need, if someone is interested. Maybe do two at a time? I will check with Novak about the parts and maybe do a work day in the near future.
I talked to Novak yesterday. The rebuild kit comes with a instruction manuel that they have put together. As far as tools. I can rent a bearing puller and should have the rest. Just need a press.
As soon as I can get the money together, I will post a work day request. I think in a month or so. Other thing I would like to do is the D20 T-case twin stick conversion. Novak said this is easy also.
the press is not a must. will just make life easier. may be able to get by with just anarbor press.i'vebeen looking at getting one. i just picked up the T-18 today so as soon as i get parts i will be getting into it.
I never got the chance to use them yet but NAPA in Conroe has a press. Before I got deployed they told be they could remove and install press fit bearings while you wait. Obviously you just gotta bring them the individual parts. Pretty cheap to. Think like 15 or 20 bucks. FYI just in case you get in a bind.
1962 Scout 80 4X4. >Stock Modified< ![]() 80/800 Hula Girl Club |
Here is a write up a I did a while back. Let me know if you have any questions.
Brett
'75 DD (in the works) all fiberglass 392 T-19 wide STaK OD 2.72s cabtop '76 (in the works) Scout II cab/cabtop - tube bed 392 T-19 wide Klune-V David LoMax 205 5.13s D60 14 bolt 1-link rear cabtop '77 DD 345 automatic D20 3.54 traveltop
| 3 speed , case , conversion , diy , fun , info , kit , manual , part , parts , project , rebuild , scout , scout 80 , size , t-18 , t-19 , t18 , t90 , tranny , transmission , vendors , work , worth |
| Hydrovac Rebuild Kit | Skip584 | General IH Tech | 1 | 01-22-2008 09:27 AM |
| low compression, runs bad etc. rebuild? efi? help me with some decisions | IHScoutman14 | General IH Tech | 22 | 09-16-2005 03:47 PM |
| carb I.D. and rebuild | kell | General IH Tech | 10 | 09-01-2005 07:24 AM |
| opinions on ebay 727 rebuild kits? | jmaroon | General IH Tech | 0 | 08-20-2005 07:56 AM |
| Engine Rebuild Gurus-this One's For You! Share Your Knowledge Please. | BeachBinder | General IH Tech | 76 | 08-15-2005 09:38 AM |
